Hello All,
I want to get Manager Information using C# API.
I found out the function in control script but i am not able to find the function in C#..
Can anyone please help me with that.
Regards
Anshuman Srivastava
Manager Status using C# API
Re: Manager Status using C# API
Can you please describe more accurate what "manager status" is in that case.
Which function in CTRL scripts are you talking about?
- Anshuman
I want to get the manager related information.
Function in control script are pmonGetCount(), pmonGetState(), pmonGetName(), pmonGetNum().
I want to know the how can i get to know the count, name and status of managers in C#
Regards
Anshuman
Regards
Anshuman
What is the information used for you want to read from the process monitor?
If a manager is running or not you can also get by reading the dp elements for the datapoint _Connections.
- Anshuman
Hi thank you for replying.
Can you explain bit more on this.
Regards
Anshuman
Regards
Anshuman
To get information for the internal dp type _Connections you can have a look at the WinCC OA Documentation: Reference tables --> Internal data point types --> _Connections.
