Error in 3.16 P006 standard panel
ozangor
Post by ozangor »
Hi there,
I do not know where to report this properly. I just thought this might be the most appropriate place.
I just found a small bug in one of the panel scripts:
panels/para/s7plus_engineering.pnl
object: pbSymb (Select button)
clicked event
line: 90
There is a missing comma in setMultiValue function args: "pbImport" "enabled", 0
Re: Error in 3.16 P006 standard panel
Thanks for the information. I have corrected the panel in the source code.
With the next patch for 3.16 the bugfix will be part of the software.
If you want to report a problem you can use the Siemens Industry Portal.
https://www.winccoa.com/knowledge-base/ ... 9f8a0d9a98
https://www.winccoa.com/knowledge-base/ ... d7ae6b1eb4
