Hello..
I have a question of snmp protocol. I have a no idea about snmp protocol. I just want to get the data from snmp server.
When I try to get the date from snmp server . I can see the integer OID thru the Wincc OA . so i can choose the OID on the
But I cannot see the digital OID thru the WinCC OA.
if you see the attached picture, the MIB browser does not show the last 3 number.
but the server side device has the value.
snmp version : snmp V1 / V2.
[SNMP] How to get the digital value
- dongil
- dongil
Re: [SNMP] How to get the digital value
can you anyone help me ?
only digital value cannot see the oid thru the mib browser. do i have to set some value on the config file ?
I can see the analog value thru the mib browser.
I do not understand what you have described.
Where did you the OID from displayed in the OID field in the PARA panel?
Have you entered it manually?
Which SNMP server are you using?
- dongil
I am doing the migration project from other program to wincc oa.
the existing program are using snmp. i got the oid from existing system.
i put the OID manually. but INT32 is working , I am getting the data from snmp server.
but digital value , I put the oid same as existing system, but it was not working, so i saw the mib browser.
the OID for digital was not displayed.
snmp version is 1 and 2.
- dongil
Do you know about below webpage ?
http://oidref.com/1.3.6.1.4.1.476.1.42.3.2.1.60
http://oidref.com/1.3.6.1.4.1.476.1.42.3.2.1.47.1
please check this web page. I cannot see the oid on wincc oa mib browser.
all digital oid i cannot see on the winccoa mib browser.
- dongil
I am still waiting your answer.
