Hi there,
I am finding that the log is being flooded with the following error:
54, Unexpeccted state, IOTransCont, outputTrans, outputTrans, Outstanding transaction for:m (Type: 2004 Sys: 1 Dp: 44290 El: 56 : _original.._value)
This is a known problem with this DPE however while it is being investigated we would like to disable this error message so it does not flood the log with unnecessary messages.
We have tried using the following config entry: IOTransitionTimeout = 0 - however this did not work.
Does anyone have any other solutions on how to disable this?
Curtis Gibson
How to disable IOTransitionTimeout errors within the log
- curtisgibson
Re: How to disable IOTransitionTimeout errors within the log
Do you need input/output addresses for this dp element?
If not you can change the settings to "in" or "out" depending on the use case.
When the dp element is not used at the moment you can also deactivate the _address config.
