Does anyone know how to remove an item from a Checkbox ?
appendItem --> OK
removeItem --> ?
Best regards.
How remove item from a Checkbox ?
Re: How remove item from a Checkbox ?
It looks like a function to remove items is missing.
Why do you want to remove items during runtime?
- luis.bustamante
I want to use a list of checkboxes like a list of elements, in some cases is better use to select.
Now I fill a list o chechboxes, to remove an item I re-fill a list.
But a list o checkboxes don't have a scrollbar when overflow.
Thanks for the answer.
If you want to have a dynamic list of options with check boxes you can use a table.
For a boolean value a checkbox can be displayed.
- uxout
I have the same requirement, is it possible to add this feature or is it too complex?
I do not know how complex it is to add this feature.
If you have several options in your panel, e.g. showing 2,3 or 4 checkboxes it is maybe easier to create 3 panel references and add/remove them by using addSymbol()/removeSymbol() instead of appending and removing checkbox items.
