3.15 Patches and RDB
1 post • Page 1 of 1
ewoenne
Post by ewoenne »
We're running a redundant distributed project using RDB with 20+ systems. We're currently running 3.15 P015 and I would like to keep the patch updated if possible but there are quite a few additional installation steps when using RDB.
- If you've run the DBschema upgrade (upgrade 8.17) when installing P015, do you need to run it again when installing P016?
- Do you only need to run the DBschema upgrade on one server in a redundant pair?
- P017 extract below. Does the Oracle password only apply if installing P017 when P016 was not installed?
'If P016 was not installed before and RDB is used please add the parameter "use_extended_oracle_types" (as defined in the RDB_config_template.sql) to your RDB_config.sql.
The Oracle password needs to be entered again in the RDB configuration panel.'
