Drag from a TREE object
tmalone
Post by tmalone »
There seems to be a few examples of the DPTREE object, but the example from the help on Drag and Drop shows a tree object, but is very limited on the answer. This panel seems to have vanished from the product.
So, I am trying to build a tree object and drag from it to TextField objects.
Here is the init code for my TREE object:
main()
dyn_string dps, MCVariables;
int i, j;
string dp;
this.columnWidthMode(TREE_WIDTH_MAXIMUM);
this.acceptDrops(FALSE);
this.showDropIndicator(TRUE);
this.selectionBehavior("1");
this.selectionMode("Single");
dps = dpNames("*", "_MC_Datasource");
for(i=1; i<=dynlen(dps); i++)
dp = dpSubStr(dps, DPSUB_DP);
this.addColumn("Data Source/Variables");
this.appendItemNC("", dp, dp);
this.dragEnabled(dp);
dpGet(dps + ".Datapoints", MCVariables);
this.appendItems(dp, MCVariables, MCVariables);
for(j=1; j<=dynlen(MCVariables); j++)
this.dragEnabled(MCVariables[j]);
So, I have the required dragEnabled on the IDs.
DragStart event looks like:
main(int keys, string id)
DebugN("drag start", keys, id);
dragStart(id, "text_left.png", DRAG_COPY);
I get no drag start. There must be an example of this somewhere?
Todd Malone
tmalone
Re: Drag from a TREE object
Post by tmalone »
this.dragEnabled(dp); // is for reading the drag enabled property
this.setDragEnabled(dp, TRUE); // is to enable the property of dragging.
