https://imgur.com/a/cFeIOzz
[I have attached 2 photos to illustrate the questions better:
SEE IMAGE 1
1. I am curious as to what the object name format is when trying to access the properties of RECT in Panel P1 in Module B with setValue or getValue
setValue example:
setValue("ModuleNamePanel.RECT ???","visible","true);getShapes example:
dyn_string shTemp;
shTemp = getShapes("ModuleName","PanelName","ShapeType","RECTANGLE");SEE IMAGE 2
3. I am curious about the naming format of the graphic object when attempting to change the attributes of the RECT in PANEL A of Module C with setValue or getValue
setValue example:
dyn_string shTemp;
