I've just downloaded WinCC OA 3.15 P017 - Windows 64bit and tried installing, no luck, the file just fails to run, regardless of running mode (ie. admin rights, or without). I wanted to try the previous patch P016, but that doesn't seem to be available in the download section.
Any suggestions on what to try? is there a way to get older version of patches somehow?
Tom
WinCC OA 3.15 P017 - EXE does not run
- schneebergera
Re: WinCC OA 3.15 P017 - EXE does not run
I just downloaded the patch WinCC OA 3.15 P017 and it was possible to install the software without failure.
Please make sure that the download completed successfully and restart the installation.
If you still require an older version, please open a service request (incl. details about your account and project).
with best regards,
with best regards,
- tpjctrl
Hi Andreas,
I've checked it on a different machine and the installation works fine, so it seems to be a problem with the VM I'm running this on.
Tom
Tom
- kilianvp
You getting a Error Message?
with best regards,
Kilian
with best regards,
Kilian
- tpjctrl
Hi Kilian,
nope, it just doesn't do anything after double clicking it. I've tried running as admin, in different compatibility modes, re-installing .net packages etc. nothing worked and in the end somehow the existing WinCC OA installation got corrupted, so I moved to a different VM where it all works fine.
Rgds,
T.
Rgds,
T.
