From a CTRL manager, I need to query all dpe names which has _archive config active.
But dpQuery doesn't return any value for '_archive.._type' or '_archive.._archive' attributes in the SELECT field.
Can you help me?
Thanks.
Query _archive config
Re: Query _archive config
Please take into account that configs which are stored during runtime of the project in the driver (_address, _smooth, _cmd_conv, _msg_conv) or in the Data Manager (_archive) cannot be read using a dpQuery() command.
Which type of archiving are you using?
- giorgiob
It's a general issue, both for HDB and RDB.
Thanks.
Thanks.
For HDB you can use the information described in the following thread:
viewtopic.php?f=15&t=9202&p=964067&hili ... ve#p964067
For RDB such a solution is not available.
If the script is running on the server you can do
-- an ASCII export for the _archive configs
-- parse the ASCII file with file commands in CTRL
