Mindsphere connector
etmKnut
Post by etmKnut »
I'm trying to figure out how to push data to mindsphere in a cyclic manner.
Should data be pushed when it changes via a dpConnect or can i make a script that sends data to mindsphere periodically? If so, how should/would i do this?
Top
Re: Mindsphere connector
If you want to execute a task in a cyclic manner in WinCC OA you can use the CTRL function timedFunc().
For detailed information please have a look at the WinCC OA Documentation.
If you need to send the value to Mindsphere when it changes (e.g. using dpConnect) or in a defined interval depends on the requirements you have.
