DP TreeView filter options
chris@blue-catalyst.co.uk
Post by chris@blue-catalyst.co.uk »
We are using the dp tree view and were wondering if there are any syntax options on the dpFilter. We are using a 2x2 redundant system and would like to show only active systems and not the passive.
We can use dpTree.dpFilter("SYSTEM1_P:*"); to show system 1 datapoints, but would like to combine this with system3, for example dpTree.dpFilter("{SYSTEM1_P:*}{SYSTEM3_P:*}");, is this possible? If so what is the syntax?
Unfortunately the help states that the filter is the width of the margin.
Thank you,
Chris
gschijndel
Re: DP TreeView filter options
Post by gschijndel »
I am afraid the filter only accepts simple patterns. Perhaps "SYSTEM[13]_P:*" works. I assume that using a filter like: "SYSTEM?_P:*" or "SYSTEM*_P:*" is not an option, because that would also return other systems.
An alternative solution would be to create your own dp tree view with the tree widget.
