Non modal window with closing
v.yarymov
Post by v.yarymov »
Hello!
How to make a panel with closure, where the user clicks on the area outside the window?
1. Open the panel (for example, a yes / no dialog)
2. Click on the area outside the panel
3. The panel closes with the false result
Re: Non modal window with closing
You can possibly solve it with the following solution.
-- For the main panel set the option "Send Mouse click" = TRUE.
When a click is made on a simple shape (not a widget) or the panel background the dp elements _Ui_<num>.MouseClick.* are set
-- Do a dpConnect() for _Ui_<num>.MouseClick.ModuleName
-- In the work function close the child panel
v.yarymov
Post by v.yarymov »
leoknipp wrote: ↑ Tue Jan 29, 2019 5:11 pm
Thanks! I'll try made it.
