ctrl++ object list
philipp.wechsler
ctrl++ object list
Post by philipp.wechsler »
Is there a way to create a list, array or dyn_... of ctrl++ objects? Or can I implement a generic list?
With kind regards
Philipp
philipp.wechsler
Re: ctrl++ object list
There is an easy way to create a list of objects with dyn_anytype. After troubleshooting I found the bug of my problem.
The order of the classes in the same script is critical!
Dosn't working MWE:
class MyObject1
  private string sName;
  private dyn_anytype daObjects;
  public MyObject1( string sName = "" )
    this.sName = sName;
  public void append( MyObject2 pObject )
    dynAppend( daObjects, pObject );
  public MyObject2 getObject( int pNumb )
    return daObjects[pNumb];
class MyObject2
  public MyObject( string sName = "" )
    this.sName = sName;
If I change the order of classes then can I use classes as parameter and return value in functions. Another solution exists with separate scripts for each class.
MWE:
class MyObject2
    this.sName = sName;
class MyObject1
    this.sName = sName;
Is there a possibility of forward declaration in ctrl ++?
