Cell format
ask
Cell format
Post by ask »
I need to display ulong values in a table. How (format string) format column ( columnFormat() ) to display such values?
Default or decimal (eg. 12d) format displays wrong values.
When I use "[12u,False,False,ALIGNMENT_END,False]" table didnt accept this format string without any message.
Regards
Adam
Re: Cell format
I have tested it and I get no error when setting the format for a table column.
Which log message do you get when the format is set?
ask
Re: Cell format
Post by ask »
Code:
for(int i=1;i<=12;i++)
this.insertColumn(i);
setValue("","columnName",i,"kol"+i,
"columnFormat","this.columnName(i),"[12u,False,False,ALIGNMENT_END,False]",
"columnAlignment",i,"AlignVCenter | AlignHCenter");
After that there is no message, but values are displayed wrong way.
After adding inside the loop line:
DebugN("col nr="+i,"format="+this.columnFormat(this.columnName(i));
in log there are messages like:
["col nr=1"],["format=[0s,,,ALIGNMENT_END]"]
["col nr=2"],["format=[0s,,,ALIGNMENT_END]"] etc.
Regards
Adam
