Source used much quantity of computer system memory
k3g6645
Post by k3g6645 »
Hello, guys.
I have a question about WinCC OA
I found a problem that when I use the WinCC_OA, it used much quantity of computer system memory.
when the WinCC OA used computer system memory, the program turned off immediately.
Anyone had same situation??
Can anyone explain or provide solution?
Thank you.
WCCILdist (1), 2019.01.03 21:46:07.562, SYS, INFO, 39, Connection lost, MAN: (SYS: 21 Dist -num 1 CONN: 1), Connection has been closed
WCCILdist (1), 2019.01.03 21:46:07.562, SYS, INFO, 39, Connection lost, MAN: (SYS: 21 Dist -num 1 CONN: 1), Connection closed
WCCILdata (0), 2019.01.03 21:46:07.562, SYS, SEVERE, 160, Lost connection to system 21
WCCILredu (1), 2019.01.03 21:46:07.562, SYS, SEVERE, 160, Lost connection to system 21
WCCOActrl (9), 2019.01.03 21:46:07.562, SYS, SEVERE, 160, Lost connection to system 21
WCCOActrl (5), 2019.01.03 21:46:07.562, SYS, SEVERE, 160, Lost connection to system 21
WCCILdist (1), 2019.01.04 10:08:45.836, SYS, INFO, 4, Connected to (SYS: 21 Dist -num 1 CONN: 1) @ XXKRCHJUBG110ES (::1)
WCCILdist (1), 2019.01.04 10:08:45.868, SYS, INFO, 39, Connection lost, MAN: (SYS: 21 Dist -num 1 CONN: 1), Connection closed
WCCILdist (1), 2019.01.04 10:09:04.790, SYS, INFO, 4, Connected to (SYS: 21 Dist -num 1 CONN: 1) @ XXKRCHJUBG110ES (::1)
WCCILdata (0), 2019.01.04 10:09:04.837, SYS, INFO, 162, Got connection to system 21
WCCOActrl (1), 2019.01.04 10:09:04.837, SYS, INFO, 162, Got connection to system 21
WCCILredu (1), 2019.01.04 10:09:04.837, SYS, INFO, 162, Got connection to system 21
WCCILsplit (2), 2019.01.04 10:09:04.837, SYS, INFO, 162, Got connection to system 21
WCCOActrl (2), 2019.01.04 10:09:04.837, SYS, INFO, 162, Got connection to system 21
WCCOActrl (4), 2019.01.04 10:09:04.837, SYS, INFO, 162, Got connection to system 21
WCCOActrl (9), 2019.01.04 10:09:04.837, SYS, INFO, 162, Got connection to system 21
WCCILdist (1), 2019.01.04 10:09:40.587, SYS, INFO, 39, Connection lost, MAN: (SYS: 21 Dist -num 1 CONN: 1), Connection closed
WCCILdata (0), 2019.01.04 10:09:40.587, SYS, SEVERE, 160, Lost connection to system 21
WCCILsplit (2), 2019.01.04 10:09:40.587, SYS, SEVERE, 160, Lost connection to system 21
WCCOActrl (2), 2019.01.04 10:09:40.587, SYS, SEVERE, 160, Lost connection to system 21
WCCOActrl (5), 2019.01.04 10:09:40.587, SYS, SEVERE, 160, Lost connection to system 21
WCCILdist (1), 2019.01.04 10:48:34.744, SYS, INFO, 4, Connected to (SYS: 21 Dist -num 1 CONN: 1) @ XXKRCHJUBG110ES (::1)
WCCILdist (1), 2019.01.04 10:48:34.853, SYS, INFO, 39, Connection lost, MAN: (SYS: 21 Dist -num 1 CONN: 1), Connection closed
WCCILdist (1), 2019.01.04 10:48:53.416, SYS, INFO, 4, Connected to (SYS: 21 Dist -num 1 CONN: 1) @ XXKRCHJUBG110ES (::1)
WCCILdata (0), 2019.01.04 10:48:53.478, SYS, INFO, 162, Got connection to system 21
WCCILredu (1), 2019.01.04 10:48:53.478, SYS, INFO, 162, Got connection to system 21
WCCILsplit (2), 2019.01.04 10:48:53.478, SYS, INFO, 162, Got connection to system 21
WCCOActrl (4), 2019.01.04 10:48:53.478, SYS, INFO, 162, Got connection to system 21
WCCOActrl (9), 2019.01.04 10:48:53.478, SYS, INFO, 162, Got connection to system 21
WCCOActrl (8), 2019.01.04 10:48:53.478, SYS, INFO, 162, Got connection to system 21
WCCILdist (1), 2019.01.04 10:49:59.182, SYS, INFO, 39, Connection lost, MAN: (SYS: 21 Dist -num 1 CONN: 1), Connection closed
WCCILdata (0), 2019.01.04 10:49:59.182, SYS, SEVERE, 160, Lost connection to system 21
WCCOActrl (8), 2019.01.04 10:49:59.182, SYS, SEVERE, 160, Lost connection to system 21
WCCOActrl (9), 2019.01.04 10:49:59.182, SYS, SEVERE, 160, Lost connection to system 21
WCCOActrl (1), 2019.01.07 01:00:05.038, CTRL, WARNING, 71, DP does not exist, archiv_client.ctl Library: C:\Siemens\Automation\WinCC_OA\3.14\scripts\libs\archiv.ctl
Line: 3357, dpSet, _AlertArchivDir.Media:_original.._value
WCCOAopcua (1), 2019.01.07 22:16:56.916, SYS, WARNING, 5/opcua, OpcUaCComm in Function read, Can not read from node group @ opc.tcp://150.1.1.111:49320 (Statuscode: BadTimeout)
WCCOAopcua (3), 2019.01.07 22:16:58.791, SYS, WARNING, 5/opcua, OpcUaCComm in Function read, Can not read from node group @ opc.tcp://150.1.1.111:49320 (Statuscode: BadTimeout)
WCCOAopcua (1), 2019.01.07 22:16:59.885, SYS, WARNING, 5/opcua, OpcUaCComm in Function read, Can not read from node group @ opc.tcp://150.1.1.111:49320 (Statuscode: BadTimeout)
WCCOAopcua (1), 2019.01.07 22:17:00.885, SYS, WARNING, 5/opcua, OpcUaCComm in Function read, Can not read from node group @ opc.tcp://150.1.1.111:49320 (Statuscode: BadTimeout)
WCCILpmon (1), 2019.01.08 21:02:09.070, SYS, WARNING, 36/pmon, Blocking Manager WCCOAopcua(1) detected. No heartbeat since 30 seconds.
WCCILpmon (1), 2019.01.08 21:02:51.711, SYS, WARNING, 39/pmon, Manager WCCOAopcua(1) is no longer blocking.
WCCILpmon (1), 2019.01.08 21:46:05.428, SYS, WARNING, 36/pmon, Blocking Manager WCCOAopcua(1) detected. No heartbeat since 30 seconds.
WCCILpmon (1), 2019.01.08 21:46:28.632, SYS, WARNING, 39/pmon, Manager WCCOAopcua(1) is no longer blocking.
WCCOAopcua (1), 2019.01.12 01:08:04.237, SYS, WARNING, 17/opcua, OpcUaCServerQueue in Function push, Queue overflow @ OPC07-Queue, 100000000 exceeded, values will be discarded
WCCOAopcua (1), 2019.01.12 01:08:04.300, SYS, WARNING, 17/opcua, OpcUaCServerQueue in Function push, Queue overflow @ OPC07-Queue, 100000000 exceeded, values will be discarded
WCCOAopcua (1), 2019.01.12 01:08:04.893, SYS, WARNING, 17/opcua, OpcUaCServerQueue in Function push, Queue overflow @ OPC07-Queue, 100000000 exceeded, values will be discarded
WCCOAopcua (1), 2019.01.12 01:08:04.893, SYS, WARNING, 118, Last error already repeated 50 times. Until another output occurs, this one will be blocked.
WCCILdata (0), 2019.01.12 19:39:45.579, SYS, INFO, 0, , DataManager, stopBgMgr, Stopping WCCILdatabg
WCCILdata (0), 2019.01.12 19:39:45.579, SYS, INFO, 181, Closing connection to (SYS: 1 Data -num 1 CONN: 2)
WCCILdatabg (1), 2019.01.12 19:39:45.579, SYS, INFO, 39, Connection lost, MAN: (SYS: 1 Data -num 0 CONN: 2), Connection closed
WCCILdata (0), 2019.01.12 19:39:45.579, SYS, INFO, 39, Connection lost, MAN: (SYS: 1 Data -num 1 CONN: 2), Connection closed
WCCILdatabg (1), 2019.01.12 19:39:45.579, SYS, SEVERE, 39, Connection lost, (SYS: 1 Data -num 0 CONN: 2), exiting ...
WCCILdata (0), 2019.01.12 19:39:46.798, IMPL, WARNING, 54, Unexpected state, DataManager, mainLoop, BG manager still running - using SIGKILL
WCCILdata (0), 2019.01.12 19:39:48.813, SYS, INFO, 0, , Loading DpIdentification
WCCILdata (0), 2019.01.12 19:39:48.829, PARAM,SEVERE, 112, Emergency mode active, DataManDpInternSup, enterEmergencyMode, Low on virtual memory, entering emergency mode. Please stop programs and restart WinCC OA
WCCILpmon (1), 2019.01.12 19:39:48.923, SYS, SEVERE, 1/pmon, Emergency Mode detected, changing to wait-mode. Waiting for commands
WCCOActrl (5), 2019.01.12 20:10:39.346, CTRL, WARNING, 5/ctrl, Location of the following log entry: POPUP_MSG.ctl Library: D:\Project\M15_ISO\M15_ISO_HMI\scripts\libs\system.ctl
Line: 215
WCCOActrl (5), 2019.01.12 20:10:39.346, SYS, WARNING, 20/ctrl, getHostByName(XXKRCHJUBG110ES): Could not start thread: ?? ????? ?????? ???? ????¡ ?????? ??? ??????. (0x000005af=1455) (1455)
WCCOActrl (2), 2019.01.12 20:10:46.736, CTRL, WARNING, 5/ctrl, Location of the following log entry: LOG_ALARM.ctl Library: D:\Project\M15_ISO\M15_ISO_HMI\scripts\libs\system.ctl
Line: 215
WCCOActrl (2), 2019.01.12 20:10:46.736, SYS, WARNING, 20/ctrl, getHostByName(XXKRCHJUBG110ES): Could not start thread: ?? ????? ?????? ???? ????¡ ?????? ??? ??????. (0x000005af=1455) (1455)
WCCOActrl (4), 2019.01.12 20:10:47.190, CTRL, WARNING, 5/ctrl, Location of the following log entry: LOG_SMS.ctl Library: D:\Project\M15_ISO\M15_ISO_HMI\scripts\libs\system.ctl
Line: 215
WCCOActrl (4), 2019.01.12 20:10:47.190, SYS, WARNING, 20/ctrl, getHostByName(XXKRCHJUBG110ES): Could not start thread: ?? ????? ?????? ???? ????¡ ?????? ??? ??????. (0x000005af=1455) (1455)
WCCOActrl (8), 2019.01.12 20:11:03.393, CTRL, WARNING, 5/ctrl, Location of the following log entry: LOG_EQ_HTR.ctl Library: D:\Project\M15_ISO\M15_ISO_HMI\scripts\libs\system.ctl
Line: 215
WCCOActrl (8), 2019.01.12 20:11:03.393, SYS, WARNING, 20/ctrl, getHostByName(XXKRCHJUBG110ES): Could not start thread: ?? ????? ?????? ???? ????¡ ?????? ??? ??????. (0x000005af=1455) (1455)
WCCOActrl (9), 2019.01.12 20:11:33.847, CTRL, WARNING, 5/ctrl, Location of the following log entry: LOG_EQ_ANL.ctl Library: D:\Project\M15_ISO\M15_ISO_HMI\scripts\libs\system.ctl
Line: 215
WCCOActrl (9), 2019.01.12 20:11:33.847, SYS, WARNING, 20/ctrl, getHostByName(XXKRCHJUBG110ES): Could not start thread: ?? ????? ?????? ???? ????¡ ?????? ??? ??????. (0x000005af=1455) (1455)
WCCOAopcua (1), 2019.01.12 20:11:31.800, SYS, WARNING, 17/opcua, OpcUaCServerQueue in Function push, Queue overflow @ OPC07-Queue, 100000000 exceeded, values will be discarded
WCCOAopcua (1), 2019.01.12 20:11:39.331, SYS, INFO, 119, Last error repeated 5505524 times.
WCCOAopcua (1), 2019.01.12 20:11:39.269, SYS, WARNING, 5/opcua, OpcUaCComm in Function read, Can not read from node group @ opc.tcp://150.1.1.111:49320 (Statuscode: BadOutOfMemory)
WCCOAopcua (1), 2019.01.12 20:11:40.378, SYS, WARNING, 17/opcua, OpcUaCServerQueue in Function push, Queue overflow @ OPC07-Queue, 100000000 exceeded, values will be discarded
WCCOAopcua (1), 2019.01.12 20:11:40.394, SYS, WARNING, 17/opcua, OpcUaCServerQueue in Function push, Queue overflow @ OPC07-Queue, 100000000 exceeded, values will be discarded
WCCOAopcua (1), 2019.01.12 20:11:40.394, SYS, WARNING, 118, Last error already repeated 50 times. Until another output occurs, this one will be blocked.
WCCOActrl (7), 2019.01.12 20:11:40.956, CTRL, WARNING, 5/ctrl, Location of the following log entry: LOG_EQ_ISO.ctl Library: D:\Project\M15_ISO\M15_ISO_HMI\scripts\libs\system.ctl
Line: 215
WCCOActrl (7), 2019.01.12 20:11:40.956, SYS, WARNING, 20/ctrl, getHostByName(XXKRCHJUBG110ES): Could not start thread: ?? ????? ?????? ???? ????¡ ?????? ??? ??????. (0x000005af=1455) (1455)
WCCILproxy (1), 2019.01.12 20:11:53.566, SYS, WARNING, 38, Message could not be sent, SRC: (SYS: 12 Dist -num 1 CONN: 1) @ XXKRCHJUBG122RM:50780 DST: (SYS: 1 Dist -num 1 CONN: 2) @ XXKRCHJUBG110ES:4777 bytes to send: 7820 errno: 10055
WCCILdist (1), 2019.01.12 20:11:53.566, SYS, INFO, 39, Connection lost, MAN: (SYS: 12 Dist -num 1 CONN: 1), Connection closed
WCCILdata (0), 2019.01.12 20:11:53.566, SYS, SEVERE, 160, Lost connection to system 12
WCCOActrl (1), 2019.01.12 20:11:53.566, SYS, SEVERE, 160, Lost connection to system 12
WCCILredu (1), 2019.01.12 20:11:53.566, SYS, SEVERE, 160, Lost connection to system 12
WCCOActrl (6), 2019.01.12 20:11:53.566, SYS, SEVERE, 160, Lost connection to system 12
WCCILdist (1), 2019.01.12 20:12:04.566, SYS, INFO, 4, Connected to (SYS: 12 Dist -num 1 CONN: 1) @ XXKRCHJUBG110ES (::1)
WCCILdata (0), 2019.01.12 20:12:10.660, SYS, INFO, 162, Got connection to system 12
WCCOActrl (1), 2019.01.12 20:12:10.660, SYS, INFO, 162, Got connection to system 12
WCCILredu (1), 2019.01.12 20:12:10.660, SYS, INFO, 162, Got connection to system 12
WCCILsplit (2), 2019.01.12 20:12:10.660, SYS, INFO, 162, Got connection to system 12
WCCOActrl (6), 2019.01.12 20:12:10.660, SYS, INFO, 162, Got connection to system 12
WCCOAopcua (1), 2019.01.12 20:12:51.208, SYS, WARNING, 17/opcua, OpcUaCServerQueue in Function push, Queue overflow @ OPC07-Queue, 100000000 exceeded, values will be discarded
WCCOAopcua (1), 2019.01.12 20:12:53.489, SYS, INFO, 119, Last error repeated 5628 times.
WCCOAopcua (1), 2019.01.12 20:12:53.489, SYS, SEVERE, 54, Unexpected state, Failed to serialize message to (SYS: 1 Event -num 0 CONN: 2): Code = 2, errno = 8
WCCOAopcua (1), 2019.01.12 20:12:53.489, SYS, WARNING, 65, Wrong destination address, (SYS: 1 Event -num 0 CONN: 2), DP_MSG_COMPLEX_VC
WCCOAopcua (1), 2019.01.12 20:12:53.505, SYS, WARNING, 65, Wrong destination address, (SYS: 1 Event -num 0 CONN: 2), DP_MSG_COMPLEX_VC
WCCOAopcua (1), 2019.01.12 20:12:53.520, SYS, WARNING, 65, Wrong destination address, (SYS: 1 Event -num 0 CONN: 2), DP_MSG_COMPLEX_VC
WCCILevent (0), 2019.01.12 20:12:53.520, SYS, SEVERE, 39, Connection lost, MAN: (SYS: 1 Driver -num 1 CONN: 2), Error reading message! Hex dump follows:
WCCOAopcua (1), 2019.01.12 20:12:53.536, SYS, WARNING, 39, Connection lost, MAN: (SYS: 1 Event -num 0 CONN: 2), Connection reset by peer (10054)
WCCOAopcua (1), 2019.01.12 20:12:53.645, SYS, WARNING, 65, Wrong destination address, (SYS: 1 Event -num 0 CONN: 2), DP_MSG_COMPLEX_VC
WCCILevent (0), 2019.01.12 20:12:53.755, SYS, WARNING, 65, Wrong destination address, (SYS: 1 Driver -num 1 CONN: 2), DP_MSG_HOTLINK
WCCILevent (0), 2019.01.12 20:12:53.755, IMPL, WARNING, 54, Unexpected state, EvConnection, updateSpontNotif, hot link generated for broken connection to (SYS: 1 Driver -num 1 CONN: 2)
WCCOAopcua (1), 2019.01.12 20:12:53.926, SYS, INFO, 30/opcua, OpcUaCServerData in Function run, Disconnected from Server OPC04-main
WCCOAopcua (1), 2019.01.12 20:12:54.161, SYS, INFO, 30/opcua, OpcUaCServerData in Function run, Disconnected from Server OPC04-redu
WCCILproxy (1), 2019.01.12 20:15:25.023, SYS, WARNING, 38, Message could not be sent, SRC: (SYS: 11 Dist -num 1 CONN: 1) @ XXKRCHJUBG102OS:49751 DST: (SYS: 1 Dist -num 1 CONN: 2) @ XXKRCHJUBG110ES:4777 bytes to send: 5836 errno: 10055
WCCILdist (1), 2019.01.12 20:15:25.023, SYS, INFO, 39, Connection lost, MAN: (SYS: 11 Dist -num 1 CONN: 1), Connection closed
WCCOActrl (1), 2019.01.12 20:15:25.039, SYS, SEVERE, 160, Lost connection to system 11
WCCILredu (1), 2019.01.12 20:15:25.039, SYS, SEVERE, 160, Lost connection to system 11
WCCILsplit (2), 2019.01.12 20:15:25.039, SYS, SEVERE, 160, Lost connection to system 11
WCCOActrl (6), 2019.01.12 20:15:25.039, SYS, SEVERE, 160, Lost connection to system 11
WCCILdata (0), 2019.01.12 20:15:25.039, SYS, SEVERE, 160, Lost connection to system 11
WCCILdist (1), 2019.01.12 20:15:49.446, SYS, INFO, 4, Connected to (SYS: 11 Dist -num 1 CONN: 1) @ XXKRCHJUBG110ES (::1)
WCCILdata (0), 2019.01.12 20:15:55.540, SYS, INFO, 162, Got connection to system 11
WCCOActrl (1), 2019.01.12 20:15:55.540, SYS, INFO, 162, Got connection to system 11
WCCILredu (1), 2019.01.12 20:15:55.540, SYS, INFO, 162, Got connection to system 11
WCCILsplit (2), 2019.01.12 20:15:55.540, SYS, INFO, 162, Got connection to system 11
WCCOActrl (6), 2019.01.12 20:15:55.540, SYS, INFO, 162, Got connection to system 11
WCCOAopcua (1), 2019.01.12 20:16:44.869, SYS, SEVERE, 45/opcua, OpcUaCComm in Function connect, Can not connect to server OPC06 (opc.tcp://150.1.1.111:49320) (Statuscode: BadInternalError)
WCCOAopcua (1), 2019.01.12 20:17:00.619, SYS, INFO, 28/opcua, OpcUaCServerData in Function run, Connected to OPC06 @ opc.tcp://150.1.1.111:49320
WCCOAs7 (4), 2019.01.12 20:25:29.645, SYS, WARNING, 65, Wrong destination address, (SYS: 1 Event -num 0 CONN: 2), DP_MSG_COMPLEX_VC
WCCOAopcua (1), 2019.01.12 20:25:30.926, SYS, INFO, 28/opcua, OpcUaCServerData in Function run, Connected to OPC06 @ opc.tcp://150.1.1.112:49320
WCCOActrl (1), 2019.01.12 20:25:31.207, SYS, INFO, 181, Closing connection to (SYS: 1 Data -num 0 CONN: 2)
WCCILdata (0), 2019.01.12 20:25:31.207, SYS, INFO, 39, Connection lost, MAN: (SYS: 1 Ctrl -num 1 CONN: 2), Connection closed
WCCOActrl (1), 2019.01.12 20:25:31.207, SYS, INFO, 39, Connection lost, MAN: (SYS: 1 Data -num 0 CONN: 2), Connection closed
WCCILsplit (2), 2019.01.12 20:25:31.223, SYS, INFO, 181, Closing connection to (SYS: 1 Data -num 0 CONN: 2)
WCCILredu (1), 2019.01.12 20:25:31.223, SYS, INFO, 181, Closing connection to (SYS: 1 Data -num 0 CONN: 2)
WCCILdist (1), 2019.01.12 20:25:31.223, SYS, INFO, 181, Closing connection to (SYS: 12 Dist -num 1 CONN: 1)
WCCILredu (1), 2019.01.12 20:25:31.223, SYS, INFO, 181, Closing connection to (SYS: 1 Redu -num 1 CONN: 1)
WCCILsplit (2), 2019.01.12 20:25:31.223, SYS, INFO, 181, Closing connection to (SYS: 1 Redu -num 2 CONN: 1)
WCCILdata (0), 2019.01.12 20:25:31.223, SYS, INFO, 39, Connection lost, MAN: (SYS: 1 Dist -num 1 CONN: 2), Connection closed
WCCILdist (1), 2019.01.12 20:25:31.223, SYS, INFO, 181, Closing connection to (SYS: 11 Dist -num 1 CONN: 1)
WCCILdist (1), 2019.01.12 20:25:31.223, SYS, INFO, 39, Connection lost, MAN: (SYS: 1 Data -num 0 CONN: 2), Connection closed
WCCILdata (0), 2019.01.12 20:25:31.223, SYS, INFO, 39, Connection lost, MAN: (SYS: 1 Redu -num 1 CONN: 2), Connection closed
WCCILsplit (2), 2019.01.12 20:25:31.223, SYS, INFO, 39, Connection lost, MAN: (SYS: 1 Redu -num 2 CONN: 1), Connection closed
WCCILredu (1), 2019.01.12 20:25:31.223, SYS, INFO, 39, Connection lost, MAN: (SYS: 1 Data -num 0 CONN: 2), Connection closed
WCCILdata (0), 2019.01.12 20:25:31.223, SYS, INFO, 39, Connection lost, MAN: (SYS: 1 Redu -num 2 CONN: 2), Connection closed
WCCILsplit (2), 2019.01.12 20:25:31.223, SYS, INFO, 39, Connection lost, MAN: (SYS: 1 Data -num 0 CONN: 2), Connection closed
WCCILredu (1), 2019.01.12 20:25:31.223, SYS, INFO, 39, Connection lost, MAN: (SYS: 1 Redu -num 1 CONN: 1), Connection closed
WCCILredu (1), 2019.01.12 20:25:31.223, SYS, INFO, 63, Connection error, Closing connection to redundancy partner
WCCILsplit (2), 2019.01.12 20:25:31.223, SYS, INFO, 2, Manager Stop
WCCILredu (1), 2019.01.12 20:25:31.223, SYS, INFO, 2, Manager Stop
WCCILdist (1), 2019.01.12 20:25:31.223, SYS, INFO, 39, Connection lost, MAN: (SYS: 12 Dist -num 1 CONN: 1), Connection closed
WCCILdist (1), 2019.01.12 20:25:31.223, SYS, INFO, 39, Connection lost, MAN: (SYS: 11 Dist -num 1 CONN: 1), Connection closed
WCCILproxy (1), 2019.01.12 20:25:31.223, SYS, SEVERE, 39, Connection lost, proxyWorkerItcIOHandler::prepareToWrite() read failed. Len = -1 from: (SYS: 1 Dist -num 1 CONN: 2) @ XXKRCHJUBG110ES:4777 to: (SYS: 12 Dist -num 1 CONN: 1) @ XXKRCHJUBG122RM:50848 error: 10054 STATUS: 17
WCCILdist (1), 2019.01.12 20:25:31.223, SYS, INFO, 2, Manager Stop
WCCOActrl (1), 2019.01.12 20:25:31.223, SYS, INFO, 2, Manager Stop
WCCOAopcua (3), 2019.01.12 20:25:31.410, SYS, INFO, 30/opcua, OpcUaCServerData in Function run, Disconnected from Server OPC_W02-main
WCCOAopcua (2), 2019.01.12 20:25:31.410, SYS, INFO, 30/opcua, OpcUaCServerData in Function run, Disconnected from Server OPC_W01-main
WCCOAopcua (2), 2019.01.12 20:25:31.426, SYS, INFO, 30/opcua, OpcUaCServerData in Function run, Disconnected from Server OPC_W01-redu
WCCOAopcua (2), 2019.01.12 20:25:31.426, SYS, WARNING, 65, Wrong destination address, (SYS: 1 Event -num 0 CONN: 2), DP_MSG_COMPLEX_VC
WCCOAopcua (3), 2019.01.12 20:25:31.442, SYS, INFO, 30/opcua, OpcUaCServerData in Function run, Disconnected from Server OPC_W02-redu
WCCOAopcua (2), 2019.01.12 20:25:31.489, SYS, INFO, 30/opcua, OpcUaCServerData in Function run, Disconnected from Server OPC_W02-main
WCCOAopcua (2), 2019.01.12 20:25:31.520, SYS, INFO, 30/opcua, OpcUaCServerData in Function run, Disconnected from Server OPC_W02-redu
WCCOAopcua (2), 2019.01.12 20:25:31.535, SYS, INFO, 2/opcua, OpcUA Driver stop
WCCOAopcua (3), 2019.01.12 20:25:31.582, SYS, INFO, 2/opcua, OpcUA Driver stop
WCCOAs7 (4), 2019.01.12 20:25:31.660, SYS, INFO, 181, Closing connection to (SYS: 1 Data -num 0 CONN: 2)
WCCILdata (0), 2019.01.12 20:25:31.660, SYS, INFO, 39, Connection lost, MAN: (SYS: 1 Driver -num 4 CONN: 2), Connection closed
WCCOAs7 (4), 2019.01.12 20:25:31.660, SYS, INFO, 39, Connection lost, MAN: (SYS: 1 Data -num 0 CONN: 2), Connection closed
WCCOAs7 (4), 2019.01.12 20:25:31.660, SYS, INFO, 2, Manager Stop
WCCILevent (0), 2019.01.12 20:25:32.192, SYS, INFO, 0, , EvManager, cleanup, Event<->Event connection flush aborted after 3sec.
WCCILevent (0), 2019.01.12 20:25:32.223, SYS, INFO, 2, Manager Stop
WCCOActrl (6), 2019.01.12 20:25:32.285, SYS, WARNING, 39, Connection lost, MAN: (SYS: 1 Event -num 0 CONN: 2), Connection reset by peer (10054)
WCCOActrl (6), 2019.01.12 20:25:32.285, SYS, SEVERE, 54, Unexpected state, CtrlMgr, doConnectionClose, Lost Connection to Event Manager, exiting ...
WCCOAopcua (2), 2019.01.12 20:25:33.551, SYS, INFO, 181, Closing connection to (SYS: 1 Data -num 0 CONN: 2)
WCCILdata (0), 2019.01.12 20:25:33.551, SYS, INFO, 39, Connection lost, MAN: (SYS: 1 Driver -num 2 CONN: 2), Connection closed
WCCOAopcua (2), 2019.01.12 20:25:33.551, SYS, INFO, 39, Connection lost, MAN: (SYS: 1 Data -num 0 CONN: 2), Connection closed
WCCOAopcua (2), 2019.01.12 20:25:33.551, SYS, INFO, 2, Manager Stop
WCCOAopcua (3), 2019.01.12 20:25:33.598, SYS, INFO, 181, Closing connection to (SYS: 1 Data -num 0 CONN: 2)
WCCILdata (0), 2019.01.12 20:25:33.598, SYS, INFO, 39, Connection lost, MAN: (SYS: 1 Driver -num 3 CONN: 2), Connection closed
WCCOAopcua (3), 2019.01.12 20:25:33.598, SYS, INFO, 39, Connection lost, MAN: (SYS: 1 Data -num 0 CONN: 2), Connection closed
WCCOAopcua (3), 2019.01.12 20:25:33.598, SYS, INFO, 2, Manager Stop
WCCOActrl (6), 2019.01.12 20:25:34.317, SYS, INFO, 181, Closing connection to (SYS: 1 Data -num 0 CONN: 2)
WCCILdata (0), 2019.01.12 20:25:34.317, SYS, INFO, 39, Connection lost, MAN: (SYS: 1 Ctrl -num 6 CONN: 2), Connection closed
WCCOActrl (6), 2019.01.12 20:25:34.317, SYS, INFO, 39, Connection lost, MAN: (SYS: 1 Data -num 0 CONN: 2), Connection closed
WCCOActrl (6), 2019.01.12 20:25:34.317, SYS, INFO, 2, Manager Stop
createDb:WinCC OA Database Utility
createDb:Create new database and install internal datapoints
createDb: Version : "3.14"
createDb:From : "C:\\Siemens\\Automation\\WinCC_OA\\3.14\\"
createDb:To : "D:\\Project\\M15_ISO\\M15_ISO_HMI\\db\\wincc_oa\\"
createDb:Logfile : "D:\\Project\\M15_ISO\\M15_ISO_HMI\\log\\createDb.log"
createDb:Languages :
createDb: [10001] "en_US.utf8" ("american_usa.1252") {Active}{Para}{Meta}
createDb:[2018.07.17;15:37:12:008 ] Creating ...
createDb:[2018.07.17;15:37:20:625 ] Finished
createDb:###################
createDb:Date : 2018.07.17;15:37:12:008
createDb:========================================================
createDb:[2018.07.17;15:37:12:009 ] Copy from C:\Siemens\Automation\WinCC_OA\3.14\dbdfiles\version_3.14\ConfHist.dbd to D:\Project\M15_ISO\M15_ISO_HMI\db\wincc_oa\ConfHist.dbd
createDb:[2018.07.17;15:37:12:009 ] C:\Siemens\Automation\WinCC_OA\3.14\bin\initdb -y ConfHist
createDb:ConfHist initialized
createDb:Raima Database Manager 4.5 [Build 17]
createDb:Database Initialization Utility
createDb:Copyright (C) 1984-1997, Raima Corporation, All Rights Reserved
createDb:[2018.07.17;15:37:12:021 ] Copy from C:\Siemens\Automation\WinCC_OA\3.14\dbdfiles\version_3.14\TypeAndId.dbd to D:\Project\M15_ISO\M15_ISO_HMI\db\wincc_oa\TypeAndId.dbd
createDb:[2018.07.17;15:37:12:021 ] C:\Siemens\Automation\WinCC_OA\3.14\bin\initdb -y TypeAndId
createDb:TypeAndId initialized
createDb:[2018.07.17;15:37:12:030 ] Copy from C:\Siemens\Automation\WinCC_OA\3.14\dbdfiles\version_3.14\DbDir.dbd to D:\Project\M15_ISO\M15_ISO_HMI\db\wincc_oa\DbDir.dbd
createDb:[2018.07.17;15:37:12:031 ] C:\Siemens\Automation\WinCC_OA\3.14\bin\initdb -y DbDir
createDb:DbDir initialized
createDb:[2018.07.17;15:37:12:039 ] Copy from C:\Siemens\Automation\WinCC_OA\3.14\dbdfiles\version_3.14\BgStatus.dbd to D:\Project\M15_ISO\M15_ISO_HMI\db\wincc_oa\BgStatus.dbd
createDb:[2018.07.17;15:37:12:039 ] C:\Siemens\Automation\WinCC_OA\3.14\bin\initdb -y BgStatus
createDb:BgStatus initialized
createDb:[2018.07.17;15:37:12:048 ] Copy from C:\Siemens\Automation\WinCC_OA\3.14\dbdfiles\version_3.14\AlertDir.dbd to D:\Project\M15_ISO\M15_ISO_HMI\db\wincc_oa\AlertDir.dbd
createDb:[2018.07.17;15:37:12:048 ] C:\Siemens\Automation\WinCC_OA\3.14\bin\initdb -y AlertDir
createDb:AlertDir initialized
createDb:[2018.07.17;15:37:12:056 ] Copy from C:\Siemens\Automation\WinCC_OA\3.14\dbdfiles\version_3.14\ValHist.dbd to D:\Project\M15_ISO\M15_ISO_HMI\db\wincc_oa\empty\ValHist.dbd
createDb:[2018.07.17;15:37:12:056 ] C:\Siemens\Automation\WinCC_OA\3.14\bin\initdb -y empty\ValHist
createDb:empty\ValHist initialized
createDb:[2018.07.17;15:37:12:067 ] Copy from C:\Siemens\Automation\WinCC_OA\3.14\dbdfiles\version_3.14\DpList.dbd to D:\Project\M15_ISO\M15_ISO_HMI\db\wincc_oa\empty\DpList.dbd
createDb:[2018.07.17;15:37:12:067 ] C:\Siemens\Automation\WinCC_OA\3.14\bin\initdb -y empty\DpList
createDb:empty\DpList initialized
createDb:[2018.07.17;15:37:12:075 ] Copy from C:\Siemens\Automation\WinCC_OA\3.14\dbdfiles\version_3.14\AlertHist.dbd to D:\Project\M15_ISO\M15_ISO_HMI\db\wincc_oa\empty\AlertHist.dbd
createDb:[2018.07.17;15:37:12:075 ] C:\Siemens\Automation\WinCC_OA\3.14\bin\initdb -y empty\AlertHist
createDb:empty\AlertHist initialized
createDb:[2018.07.17;15:37:12:084 ] Copy from C:\Siemens\Automation\WinCC_OA\3.14\dbdfiles\version_3.14\AlertDpList.dbd to D:\Project\M15_ISO\M15_ISO_HMI\db\wincc_oa\empty\AlertDpList.dbd
createDb:[2018.07.17;15:37:12:084 ] C:\Siemens\Automation\WinCC_OA\3.14\bin\initdb -y empty\AlertDpList
createDb:empty\AlertDpList initialized
createDb:[2018.07.17;15:37:12:092 ] Copy from C:\Siemens\Automation\WinCC_OA\3.14\dbdfiles\version_3.14\ValHist.dbd to D:\Project\M15_ISO\M15_ISO_HMI\db\wincc_oa\ancient\ValHist.dbd
createDb:[2018.07.17;15:37:12:093 ] C:\Siemens\Automation\WinCC_OA\3.14\bin\initdb -y ancient\ValHist
createDb:ancient\ValHist initialized
createDb:[2018.07.17;15:37:12:103 ] Copy from C:\Siemens\Automation\WinCC_OA\3.14\dbdfiles\version_3.14\AlertHist.dbd to D:\Project\M15_ISO\M15_ISO_HMI\db\wincc_oa\alliving\AlertHist.dbd
createDb:[2018.07.17;15:37:12:103 ] C:\Siemens\Automation\WinCC_OA\3.14\bin\initdb -y alliving\AlertHist
createDb:alliving\AlertHist initialized
createDb:[2018.07.17;15:37:12:112 ] Copy from C:\Siemens\Automation\WinCC_OA\3.14\dbdfiles\version_3.14\AlertHist.dbd to D:\Project\M15_ISO\M15_ISO_HMI\db\wincc_oa\aloverflow\AlertHist.dbd
createDb:[2018.07.17;15:37:12:113 ] C:\Siemens\Automation\WinCC_OA\3.14\bin\initdb -y aloverflow\AlertHist
createDb:aloverflow\AlertHist initialized
createDb:[2018.07.17;15:37:12:122 ] Copy from C:\Siemens\Automation\WinCC_OA\3.14\dbdfiles\version_3.14\ValHist.dbd to D:\Project\M15_ISO\M15_ISO_HMI\db\wincc_oa\lastval\ValHist.dbd
createDb:[2018.07.17;15:37:12:122 ] C:\Siemens\Automation\WinCC_OA\3.14\bin\initdb -y lastval\ValHist
createDb:lastval\ValHist initialized
createDb:[2018.07.17;15:37:12:519 ] C:\Siemens\Automation\WinCC_OA\3.14\bin\WCCOAtoolSysNames -yes -s=C:\Siemens\Automation\WinCC_OA\3.14\dbdfiles\version_3.14\tesystem.txt -log +stderr
createDb:PVSS_2 Database Utility (!!!!! Internal Use Only !!!!)
createDb:Setup database system settings, (system No. & names)
createDb:DataBase Found at : "D:\\Project\\M15_ISO\\M15_ISO_HMI\\db\\wincc_oa\\"
createDb:SETTINGS :
createDb:System Number : 1
createDb:Number Of Languages : 1
createDb:-yes (NoConfirm) : 1
createDb:File name : C:\Siemens\Automation\WinCC_OA\3.14\dbdfiles\version_3.14\tesystem.txt
createDb:Name [1] = System1
createDb:HighestAssignedDpId : 0
createDb:HighestAssignedTypeId : 0
createDb:HighestAssignedViewId : 0
createDb:STORED OK
createDb:System Nr : 1
createDb:m_iNofLanguages : 1
createDb:[2018.07.17;15:37:12:744 ] C:\Siemens\Automation\WinCC_OA\3.14\bin\WCCILdata -log +stderr -log -file -data localhost -event localhost
createDb:[2018.07.17;15:37:13:179 ] C:\Siemens\Automation\WinCC_OA\3.14\bin\WCCILevent -log +stderr -log -file -data localhost -event localhost
createDb:[2018.07.17;15:37:13:239 ] C:\Siemens\Automation\WinCC_OA\3.14\bin\WCCILsim -log +stderr -log -file -data localhost -event localhost -num 1
createDb:[2018.07.17;15:37:13:281 ] C:\Siemens\Automation\WinCC_OA\3.14\bin\WCCOAascii -inactivateAlert -yes -log +stderr -log -file -data localhost -event localhost -in C:\Siemens\Automation\WinCC_OA\3.14\dbdfiles\version_3.14\dptypes.txt
createDb:WCCOAascii (0), 2018.07.17 15:37:13.312, SYS, INFO, 1, Manager Start, PROJ, M15_ISO_HMI, V 3.14 - 3.14 platform Windows AMD64 linked at Dec 7 2017 10:40:37
createDb:WCCOAascii (0), 2018.07.17 15:37:13.313, SYS, INFO, 3, Trying to connect to (SYS: 0 Data -num 0 CONN: 1) @ localhost:4897
createDb:WCCOAascii (0), 2018.07.17 15:37:13.314, SYS, INFO, 4, Connected to (SYS: 0 Data -num 0 CONN: 1) @ XXKRCHJUBG109ES (::1)
createDb:WCCOAascii (1), 2018.07.17 15:37:13.315, SYS, INFO, 6, Initialization by Data Manager finished
createDb:WCCOAascii (1), 2018.07.17 15:37:13.315, SYS, INFO, 3, Trying to connect to (SYS: 1 Event -num 0 CONN: 1) @ localhost:4998
createDb:WCCOAascii (1), 2018.07.17 15:37:13.315, SYS, INFO, 4, Connected to (SYS: 1 Event -num 0 CONN: 1) @ XXKRCHJUBG109ES (::1)
createDb:WCCOAascii (1), 2018.07.17 15:37:13.322, PARAM,WARNING, 7, Datapoint does not exist, UserTable, UserTable, _Users.UserId
createDb:WCCOAascii (1), 2018.07.17 15:37:13.322, PARAM,WARNING, 7, Datapoint does not exist, ManagerTable, ManagerTable, _Managers.Auth.ManType
createDb:processing file C:\Siemens\Automation\WinCC_OA\3.14\dbdfiles\version_3.14\dptypes.txt
createDb:DpType (9): Create msg for type _AlertFilter sent.
createDb:DpType (38): Create msg for type _AlertRow sent.
createDb:DpType (61): Create msg for type _AlertSaveRestore sent.
createDb:DpType (67): Create msg for type _System sent.
createDb:DpType (69): Create msg for type _AsciiManager sent.
createDb:DpType (81): Create msg for type _ChildPanel sent.
createDb:DpType (89): Create msg for type _DataBgManager sent.
createDb:DpType (109): Create msg for type _DataSaveRestore sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (171): Create msg for type _DataSet sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (182): Create msg for type _DiskSpaceCheck sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (191): Create msg for type _MemoryCheck sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (209): Create msg for type _KR sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (222): Create msg for type _DPM sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (227): Create msg for type _Layer sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (228): Create msg for type _AlertClass sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (231): Create msg for type _Module sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (242): Create msg for type _ModuleOn sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (246): Create msg for type _Panel sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (255): Create msg for type _Printer sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (259): Create msg for type _PrintPanel sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (265): Create msg for type _RootPanel sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (281): Create msg for type _Service sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (282): Create msg for type _SilentPrint sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (286): Create msg for type _Simulator sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (302): Create msg for type _TimedFunc sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (311): Create msg for type _RK512 sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (354): Create msg for type _SSI_SysMsg sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (375): Create msg for type _SSI_SysAll sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (383): Create msg for type _SSI_Alive sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (416): Create msg for type _SSI_DaDf sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (417): Create msg for type _SSI_Impulse_Type sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (483): Create msg for type _ArchivControl sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (509): Create msg for type _Archive sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (511): Create msg for type _ArchiveManager sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (515): Create msg for type _ArchivDir sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (526): Create msg for type _MediaConfig sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (537): Create msg for type ExampleDP_BarTrend sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (538): Create msg for type
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (688): Create msg for type _Statistics_EventConfigs sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (693): Create msg for type _Statistics_DriverConfigs sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (695): Create msg for type _Statistics_DataConfigs sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (697): Create msg for type _Statistics_Refresh sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (712): Create msg for type _CompressStructure sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (837): Create msg for type _ValueArchive sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (848): Create msg for type _ValueArchivMedia sent.
createDb:Disk Space Check changed in 3.14 but do not move to upgrade_dptypes because it is upgraded by script (851): Create msg for type _CtrlDebug sent.
createDb:VarTrend (867): Create msg for type _AcStructure sent.
createDb:VarTrend (882): Create msg for type _VarTrend sent.
createDb:VarTrend (886): Create msg for type _VarTrendOpen sent.
createDb:VarTrend (892): Create msg for type _DpGroup sent.
createDb:STD-Symbols (911): Create msg for type ANALOG1 sent.
createDb:STD-Symbols (925): Create msg for type ANALOG2 sent.
createDb:STD-Symbols (940): Create msg for type COUNTER_SUB sent.
createDb:STD-Symbols (956): Create msg for type COUNTER1 sent.
createDb:STD-Symbols (973): Create msg for type WH_SC_SERVICE sent.
createDb:STD-Symbols (988): Create msg for type WH_SC_SUB sent.
createDb:STD-Symbols (1003): Create msg for type WH_SC1 sent.
*** skipping 686499 bytes from createDb.log ***
createDb:Waiting for last response from eventmanager...
createDb:Scanning of file C:\Siemens\Automation\WinCC_OA\3.14\dbdfiles\version_3.14\update_configs.txt is finished (0)
createDb:End of Program
createDb:WCCOAascii (1), 2018.07.17 15:37:16.010, SYS, INFO, 2, Manager Stop
createDb:[2018.07.17;15:37:16:013 ] C:\Siemens\Automation\WinCC_OA\3.14\bin\WCCOAascii -inactivateAlert -yes -log +stderr -log -file -data localhost -event localhost -in C:\Siemens\Automation\WinCC_OA\3.14\dbdfiles\version_3.14\examples.txt
createDb:WCCOAascii (0), 2018.07.17 15:37:16.044, SYS, INFO, 1, Manager Start, PROJ, M15_ISO_HMI, V 3.14 - 3.14 platform Windows AMD64 linked at Dec 7 2017 10:40:37
createDb:WCCOAascii (0), 2018.07.17 15:37:16.046, SYS, INFO, 3, Trying to connect to (SYS: 0 Data -num 0 CONN: 1) @ localhost:4897
createDb:WCCOAascii (0), 2018.07.17 15:37:16.047, SYS, INFO, 4, Connected to (SYS: 0 Data -num 0 CONN: 1) @ XXKRCHJUBG109ES (::1)
createDb:WCCOAascii (1), 2018.07.17 15:37:16.051, SYS, INFO, 6, Initialization by Data Manager finished
createDb:WCCOAascii (1), 2018.07.17 15:37:16.051, SYS, INFO, 3, Trying to connect to (SYS: 1 Event -num 0 CONN: 1) @ localhost:4998
createDb:WCCOAascii (1), 2018.07.17 15:37:16.052, SYS, INFO, 4, Connected to (SYS: 1 Event -num 0 CONN: 1) @ XXKRCHJUBG109ES (::1)
createDb:WCCOAascii (1), 2018.07.17 15:37:16.059, SYS, INFO, 102, Waiting for user names/passwords
createDb:WCCOAascii (1), 2018.07.17 15:37:16.059, SYS, INFO, 103, User names/passwords initialized
createDb:processing file C:\Siemens\Automation\WinCC_OA\3.14\dbdfiles\version_3.14\examples.txt
createDb:Scanning of file C:\Siemens\Automation\WinCC_OA\3.14\dbdfiles\version_3.14\examples.txt is finished (0)
createDb:WCCOAascii (1), 2018.07.17 15:37:16.066, SYS, INFO, 2, Manager Stop
createDb:[2018.07.17;15:37:20:203 ] C:\Siemens\Automation\WinCC_OA\3.14\bin\WCCOAtoolSyncTypes -system 1 SVR_ISO
createDb:-------------------------------------------------------
createDb:Finished : 2018.07.17;15:37:20:625
WCCOAopcua (1), 2019.01.12 21:01:33.493, SYS, WARNING, 5/opcua, OpcUaCComm in Function read, Can not read from node group @ opc.tcp://150.1.1.111:49320 (Statuscode: BadTimeout)
WCCOAopcua (1), 2019.01.12 21:10:11.185, SYS, WARNING, 65, Wrong destination address, (SYS: 1 Event -num 0 CONN: 2), DP_MSG_COMPLEX_VC
WCCOAopcua (1), 2019.01.12 21:10:12.076, SYS, WARNING, 65, Wrong destination address, (SYS: 1 Event -num 0 CONN: 2), DP_MSG_COMPLEX_VC
WCCOAopcua (1), 2019.01.12 21:10:15.420, SYS, INFO, 30/opcua, OpcUaCServerData in Function run, Disconnected from Server OPC05-main
WCCOAopcua (1), 2019.01.12 21:10:16.904, SYS, INFO, 30/opcua, OpcUaCServerData in Function run, Disconnected from Server OPC05-redu
WCCOAvalarch (2), 2019.01.12 21:39:49.152, IMPL, WARNING, 54, Unexpected state, Archive, doOnlineBackup, Elapsed timeout during the online backup operation
WCCOAvalarch (3), 2019.01.12 21:39:49.152, IMPL, WARNING, 54, Unexpected state, Archive, doOnlineBackup, Elapsed timeout during the online backup operation
WCCOAvalarch (1), 2019.01.12 21:39:49.152, IMPL, WARNING, 54, Unexpected state, Archive, doOnlineBackup, Elapsed timeout during the online backup operation
WCCOAvalarch (5), 2019.01.12 21:39:49.184, IMPL, WARNING, 54, Unexpected state, Archive, doOnlineBackup, Elapsed timeout during the online backup operation
WCCOAvalarch (0), 2019.01.12 21:39:49.215, IMPL, WARNING, 54, Unexpected state, Archive, doOnlineBackup, Elapsed timeout during the online backup operation
WCCOAvalarch (4), 2019.01.12 21:39:49.324, IMPL, WARNING, 54, Unexpected state, Archive, doOnlineBackup, Elapsed timeout during the online backup operation
WCCOAopcua (1), 2019.01.12 21:47:11.080, SYS, WARNING, 65, Wrong destination address, (SYS: 1 Event -num 0 CONN: 2), DP_MSG_COMPLEX_VC
WCCOAopcua (1), 2019.01.12 21:47:11.721, SYS, WARNING, 65, Wrong destination address, (SYS: 1 Event -num 0 CONN: 2), DP_MSG_COMPLEX_VC
WCCOAopcua (1), 2019.01.12 21:47:14.330, SYS, INFO, 30/opcua, OpcUaCServerData in Function run, Disconnected from Server OPC06-main
WCCOAopcua (1), 2019.01.12 21:47:14.533, SYS, INFO, 30/opcua, OpcUaCServerData in Function run, Disconnected from Server OPC06-redu
WCCOAopcua (1), 2019.01.12 22:03:56.453, SYS, WARNING, 5/opcua, OpcUaCComm in Function read, Can not read from node group @ opc.tcp://150.1.1.111:49320 (Statuscode: BadTimeout)
WCCOAopcua (1), 2019.01.12 22:25:40.557, SYS, WARNING, 65, Wrong destination address, (SYS: 1 Event -num 0 CONN: 2), DP_MSG_COMPLEX_VC
WCCOAopcua (1), 2019.01.12 22:25:40.619, SYS, WARNING, 65, Wrong destination address, (SYS: 1 Event -num 0 CONN: 2), DP_MSG_COMPLEX_VC
WCCOAopcua (1), 2019.01.12 22:25:44.354, SYS, INFO, 30/opcua, OpcUaCServerData in Function run, Disconnected from Server OPC07-main
WCCOAopcua (1), 2019.01.12 22:25:44.525, SYS, INFO, 30/opcua, OpcUaCServerData in Function run, Disconnected from Server OPC07-redu
WCCOAopcua (1), 2019.01.12 22:45:26.541, SYS, WARNING, 65, Wrong destination address, (SYS: 1 Event -num 0 CONN: 2), DP_MSG_COMPLEX_VC
WCCOAopcua (1), 2019.01.12 22:45:26.901, SYS, WARNING, 65, Wrong destination address, (SYS: 1 Event -num 0 CONN: 2), DP_MSG_COMPLEX_VC
WCCOAopcua (1), 2019.01.12 22:45:27.198, SYS, INFO, 30/opcua, OpcUaCServerData in Function run, Disconnected from Server OPC08-main
WCCOAopcua (1), 2019.01.12 22:45:27.588, SYS, INFO, 30/opcua, OpcUaCServerData in Function run, Disconnected from Server OPC08-redu
WCCOAopcua (1), 2019.01.12 22:45:27.682, SYS, WARNING, 65, Wrong destination address, (SYS: 1 Event -num 0 CONN: 2), DP_MSG_COMPLEX_VC
WCCOAopcua (1), 2019.01.12 22:45:27.916, SYS, INFO, 30/opcua, OpcUaCServerData in Function run, Disconnected from Server OPC09-main
WCCOAopcua (1), 2019.01.12 22:45:28.057, SYS, INFO, 30/opcua, OpcUaCServerData in Function run, Disconnected from Server OPC09-redu
WCCOAopcua (1), 2019.01.12 22:45:28.198, SYS, WARNING, 65, Wrong destination address, (SYS: 1 Event -num 0 CONN: 2), DP_MSG_COMPLEX_VC
WCCOAopcua (1), 2019.01.12 22:45:30.838, SYS, INFO, 30/opcua, OpcUaCServerData in Function run, Disconnected from Server OPC21-main
WCCOAopcua (1), 2019.01.12 22:45:31.026, SYS, INFO, 30/opcua, OpcUaCServerData in Function run, Disconnected from Server OPC21-redu
WCCOAopcua (1), 2019.01.12 23:35:37.493, SYS, WARNING, 65, Wrong destination address, (SYS: 1 Event -num 0 CONN: 2), DP_MSG_COMPLEX_VC
WCCOAopcua (1), 2019.01.12 23:35:41.102, SYS, WARNING, 65, Wrong destination address, (SYS: 1 Event -num 0 CONN: 2), DP_MSG_COMPLEX_VC
WCCOAopcua (1), 2019.01.12 23:35:41.118, SYS, WARNING, 65, Wrong destination address, (SYS: 1 Event -num 0 CONN: 2), DP_MSG_COMPLEX_VC
WCCOAopcua (1), 2019.01.12 23:35:54.696, SYS, INFO, 30/opcua, OpcUaCServerData in Function run, Disconnected from Server OPC22-main
WCCOAopcua (1), 2019.01.12 23:35:56.571, SYS, INFO, 30/opcua, OpcUaCServerData in Function run, Disconnected from Server OPC22-redu
WCCOAopcua (1), 2019.01.13 00:01:16.264, SYS, WARNING, 65, Wrong destination address, (SYS: 1 Event -num 0 CONN: 2), DP_MSG_COMPLEX_VC
WCCOAopcua (1), 2019.01.13 00:01:16.279, SYS, WARNING, 65, Wrong destination address, (SYS: 1 Event -num 0 CONN: 2), DP_MSG_COMPLEX_VC
WCCOAopcua (1), 2019.01.13 00:01:18.607, SYS, INFO, 30/opcua, OpcUaCServerData in Function run, Disconnected from Server OPC23-main
WCCOAopcua (1), 2019.01.13 00:01:18.795, SYS, INFO, 30/opcua, OpcUaCServerData in Function run, Disconnected from Server OPC23-redu
WCCOAopcua (1), 2019.01.13 00:11:48.620, SYS, INFO, 2/opcua, OpcUA Driver stop
WCCOAopcua (1), 2019.01.13 00:11:50.635, SYS, INFO, 181, Closing connection to (SYS: 1 Data -num 0 CONN: 2)
WCCILdata (0), 2019.01.13 00:11:50.651, SYS, INFO, 39, Connection lost, MAN: (SYS: 1 Driver -num 1 CONN: 2), Connection closed
WCCOAopcua (1), 2019.01.13 00:11:50.682, SYS, INFO, 39, Connection lost, MAN: (SYS: 1 Data -num 0 CONN: 2), Connection closed
WCCOAopcua (1), 2019.01.13 00:11:51.026, SYS, INFO, 2, Manager Stop
WCCILdata (0), 2019.01.14 13:01:14.371, SYS, INFO, 39, Connection lost, MAN: (SYS: 0 Data -num 0 CONN: 1), Connection has been closed
WCCILdata (0), 2019.01.14 13:01:14.527, SYS, INFO, 39, Connection lost, MAN: (SYS: 0 Data -num 0 CONN: 1), Connection closed
WCCILdata (0), 2019.01.14 13:05:25.312, PARAM,WARNING, 112, Emergency mode active
WCCILdata (0), 2019.01.14 13:05:25.390, SYS, INFO, 4, Connected to (SYS: 0 Data -num 0 CONN: 1) @ XXKRCHJUBG110ES (::1)
WCCILdata (0), 2019.01.14 13:05:25.452, REDU, WARNING, 0, , Got recovery request but we are in emergency mode. Sending definite reject.
WCCILdata (0), 2019.01.14 13:05:27.468, SYS, INFO, 39, Connection lost, MAN: (SYS: 0 Data -num 0 CONN: 1), Connection closed
WCCILdata (0), 2019.01.14 13:12:17.211, PARAM,WARNING, 112, Emergency mode active
WCCILdata (0), 2019.01.14 13:12:17.211, SYS, INFO, 4, Connected to (SYS: 0 Data -num 0 CONN: 1) @ XXKRCHJUBG110ES (::1)
WCCILdata (0), 2019.01.14 13:12:17.211, REDU, WARNING, 0, , Got recovery request but we are in emergency mode. Sending definite reject.
WCCILdata (0), 2019.01.14 13:12:19.226, SYS, INFO, 39, Connection lost, MAN: (SYS: 0 Data -num 0 CONN: 1), Connection closed
Re: Source used much quantity of computer system memory
First of all please check which programs are you using a lot of memory and/or CPU.
Most of the time an increasing memory usage occurs if also a lot of CPU is used.
On Windows you can use the Windows Performance Monitor to trace the CPU/memory usage.
A description you can find in the Knowledge Base.
https://www.winccoa.com/knowledge-base/ ... e9cd3b088c
k3g6645
Post by k3g6645 »
leoknipp wrote: ↑ Wed Jan 16, 2019 10:07 am Thank you for your answer.
I found the problem.
It named "WCCOAopcua Executable."
It's program used low quantity of computer CPU ( only used 1% of cpu )
but used much quantity of computer system memory. ( more than 10% of memory and time goes on the memory usage increasing more and more ) and then, it turned off !
Can you give some advises for this problem?
Thank you.
In your initial posting the information is given that you have installed V 3.14 - 3.14 platform Windows AMD64 linked at Dec 7 2017 10:40:37.
First of all please make an upgrade to the newest patch P023.
Afterwards please check if the problem still occurs.
