Change OPC DA driver number in a scripts
- dceballos
Is it possible to change the driver number of an OPC DA at runtime in a script? Thanks
Re: Change OPC DA driver number in a scripts
Is your question related to the driver number defined at the _distrib config (within the _address configuration panel)?
Or is related to the driver number defined when starting the OPC DA client (progs file)?
- dceballos
Good Morning. Already solved. It was _distrib. Thank you so much.
Plesase take into account that you have to configure all driver related configs (_address, _smooth, _cmd_conv, _msg_conv) again if you have the driver number for the ´_distrib config.
Only those configs which you have added before you need to reconfigure.
