Hello to all!
I think that my task is simple, but i didn't found anything about that in Help/
So, I need to start and stop WinCC OA managers from ctrl-script.
Additional task - to create managers dynamically start\stop them, delete them from ctrl script.
Is there any way to do that?
How To start and stop managers from ctrl-script
- NFedorenko
Re: How To start and stop managers from ctrl-script
To stop a manager (connected to the Event Manager) you can simply write the manager ID to the DP-element _Managers(_2).Exit.
If you want to start a process you can use the system() command. When you start a WinCC OA process using the system() command the process monitor WCCILpmon will not observe this manager.
When you want to start and stop a WinCC OA process managed by the WCCILpmon you can use the (internal) commands defined in the CTRL library pmon.ctl.
