Cannot reset password in WinCC OA 3.14
nmnogueira
Post by nmnogueira »
I'm using WinCC OA 3.14 P022, and the "Reset password" button is not visible. The panel is encrypted so I cannot find out why.
Anyone with the same issue?
Re: Cannot reset password in WinCC OA 3.14
In the code for WinCC OA 3.14 I have not seen a code which sets the button invisible.
Is the button disabled or not visible?
Which patch of 3.14 are you using?
nmnogueira
The button is invisible. I am using P022.
Nuno
schneebergera
Post by schneebergera »
which panel you are using - is it a panel created by your own?
If the panel topology is properly configured, you can access the panel (vision/changePassword.pnl) by right-clicking on the username in infoPanel (for example, TEMPLATE1).
There the password of the user can be changed. To reset the password, you must be root user or a user with the authority (para) to be able to update the dp. Otherwise the button is not visible.
with best regards,
