DP list in DPGroups
hakan
DP list in DPGroups
Post by hakan »
How can I take list defined dp of the the DPgroups. Which function can be use for this issue?
Thank you
Re: DP list in DPGroups
I'm not sure if I understood what you have described.
Do you want to get a list of all dp groups or do you want to get the list of dp elements defined in one dp group?
Why do you want to know the list of elements in one group? What is the result used for?
hakan
Post by hakan »
I want to get the list of dp elements defined in one dp group. We will use the dp elements defined in the dp group for sending email common message. The dp elements can be defined in this dp group by operator.
Control script always check this dp elements in the dp group
You can have a look at the code for the panel vision/groups/dpGroupsEdit_CheckGroup.pnl.
This panel displays the elements defined a dp group.
