I am trying to use dpWaitForValue as shown below. It works for me but I notice that if the condition is already met before the dpWaitForValue function runs.it does Not recognize the value, and just sits and waits for it ..the only way I can get it to recognize is if I change back to false and make true again. Is there a way around this? I want the function to proceed running the script if the condition is already met.
Also can I OR and && dpWaitForValue funtions something like
(dpWaitForValue( dpNamesWait, conditions1, dpNamesReturn, returnValues, t ))||(dpWaitForValue( dpNamesWait, conditions2, dpNamesReturn, returnValues, t ));
Thank you.
Lori
main(mapping event)
DebugN("Running");
time t;
dyn_string dpNamesWait, dpNamesReturn;
dyn_anytype returnValues,condition3;
int status;
// assignment of the data points for dpNamesWait
dpNamesWait = makeDynString("System1:global_vars.OnlineStatus:_original.._value");
// indication of the condition that must be fulfilled
condition3=makeDynBool((bool)1);
// assignment of the data points for dpNamesReturn (data points
// of the child panel that is parameterised for buttons
t = 60;
// The child panel is opened
status=dpWaitForValue(dpNamesWait, condition3, dpNamesReturn, returnValues, t) ;
DebugN("I just waited for control mode to == 100 or 200", dpNamesReturn,returnValues);
dpWaitForValue
Re: dpWaitForValue
In the OR condition the return values of the function are compared.
It is not a comparison for the return values of dpWaitForValue.
dpWaitForValue() checks the conditions when a value is set, similar to a work function for a dpConnect().
You can probably do the following:
-- make a dpConnect for the dp element you want to wait for
-- write the result to a global variable
-- before starting dpWaitForValue read the global variable
-- if the value does not fit the condition you are waiting for the function dpWaitForValue is started
