• Page 1 of 1
chandra
Screen Resolution wrong
Postby chandra »
Dear All,
I am using a panel topology, my template resolution is 1920 X 1080 it is working good on the same PC, but if I open UI from ULC client in the browser or maybe from Remote UI I am getting a resolution wrong panel.
please tell me what needs to be done, I tried with the following config entries but I am facing the same problem.
In this case it depends in the client screen resolution , if the resolution on the client station doesn't equal to 1920*1080 then it will open the default panel topology template. You can solve this issue by copying the base and navigation panels on your server and paste again after that rename the newly made panels by the resolution of the client.
Regards
