Client loses Connection occasionally with server
cofelyhoogland
Post by cofelyhoogland »
We have connected two clients to the WINCC-OA Scada server.
One client occasionally lost connection with the server .
This is the log of the server:
=====Begin log
PVSS00event (0), 2018.11.08 13:04:24.037, SYS, INFO, 4, Connected to, (SYS: 1 Ui -num 7 CONN: 1(R)) @ TDMCU001 (::ffff:10.35.120.23)
PVSS00event (0), 2018.11.08 13:11:25.194, SYS, WARNING, 39, Connection lost, MAN: (SYS: 1 Ui -num 7 CONN: 1(R)), Connection reset by peer (10054)
PVSS00event (0), 2018.11.08 13:11:25.206, SYS, WARNING, 65, Wrong destination address, (SYS: 1 Ui -num 7 CONN: 1(R)), DP_MSG_HOTLINK
PVSS00event (0), 2018.11.08 13:11:25.206, IMPL, WARNING, 54, Unexpected state, EvConnection, updateSpontNotif, hot link generated for broken connection to (SYS: 1 Ui -num 7 CONN: 1(R))
PVSS00event (0), 2018.11.08 13:11:25.221, SYS, WARNING, 65, Wrong destination address, (SYS: 1 Ui -num 7 CONN: 1(R)), DP_MSG_HOTLINK
PVSS00event (0), 2018.11.08 13:11:25.221, IMPL, WARNING, 54, Unexpected state, EvConnection, updateSpontNotif, hot link generated for broken connection to (SYS: 1 Ui -num 7 CONN: 1(R))
PVSS00data (0), 2018.11.08 13:11:27.253, SYS, INFO, 39, Connection lost, MAN: (SYS: 1 Ui -num 7 CONN: 1(R)), Connection closed
PVSS00data (0), 2018.11.08 13:11:27.539, SYS, INFO, 4, Connected to, (SYS: 1 Ui -num 7 CONN: 1(R)) @ TDMCU001 (::ffff:10.35.120.23)
PVSS00data (0), 2018.11.08 13:11:27.763, SYS, INFO, 0, , Manager (SYS: 1 Ui -num 7 CONN: 1(R)) initialised
PVSS00event (0), 2018.11.08 13:11:35.754, SYS, INFO, 4, Connected to, (SYS: 1 Ui -num 7 CONN: 1(R)) @ TDMCU001 (::ffff:10.35.120.23)
=====End log
Would anyone happen to know what this warning message means and how it can be fixed or prevented?
Henk
Re: Client loses Connection occasionally with server
In case of a connection loss you always have to look at the PVSS_II.log file for the server and the client.
"Connection reset by peer" simply means that the communication partner (peer) has closed the connection.
cofelyhoogland
Thanks for the response
