Error \"Connection reset by peer (10054)
Chandan
Post by Chandan »
Dear Experts,
We are having five numbers of clients connected to the Wincc OA Server.
Today one of the client (Wincc Desktop UI) got disconnected from the server, we checked
the Ethernet connection and other things found everything ok. We tried
to connect the client but it is not getting connected to the server.
In the log files I am getting the Error 10054, connection reset by peer.
I don't understand the meaning of this and the reason for this message.
Please find the attached log file from the PVSSII.
Please check these files and will be obliged if you revert me with the reason
and solution to this issue ASAP.
Regards
Chandan.
schneebergera
Re: Error \"Connection reset by peer (10054)
Post by schneebergera »
unfortunately, the logs are not attached.
Please check the license file for free connections.
Can you recognize the registered client in the device manager.
best regards,
In case of a connection loss you always have to look at the PVSS_II.log file for the server and the client.
"Connection reset by peer" simply means that the communication partner (peer) has closed the connection.
