No writable system menu directory found.
Posted: Mon Dec 03, 2012 1:19 pm
by frankySie
a linux installation shows this error:
xdg-desktop-menu: No writable system menu directory found.
error: %post(WinCC_OA_3.11-help-en-0-0.i386) scriptlet failed, exit status 3
error: %post(WinCC_OA_3.11-help-de-0-0.i386) scriptlet failed, exit status 3
What does this error mean?
Is it critical?
What folder should it be?
https://www.winccoa.com/fileadmin/image ... gError.txt
Re: No writable system menu directory found.
Posted: Tue Dec 04, 2012 11:04 pm
by mkoller
It seems that you neither run a KDE nor a GNOME session on this PC, so the installation does not know where to install
the "startmenu" entries to.
I think it should not pose a problem but I never checked that case.
P.S:The mentioned xdg command is a shellscript which we install in the bin dir - you can check what it does.
