call a given callback function from an control extension (dll)
Posted: Wed May 04, 2016 7:45 pm
by mmarchha
Is there a way that a own control extension can call a callback function?
One example usescase would be that your control extension has a function that starts a calculation that might take a while an in your code you do not require the result immediately but you like to get a notification with the result.
e.g:
//button clicked event
    registerResultCallBack("resultCB");   //function in your control extension to register the callback function that should be called
    startCalculation();   //function in your control extension that starts the calculation
resultCB(int value)   //function that is called from your control extension as soon as the calculation has finished
   txt1.text = value;
If it is possible, are there any examples available how to implement this?
Re: call a given callback function from an control extension (dll)
Posted: Thu May 05, 2016 2:31 pm
by mkoller
Yes, this is possible and easy to do. E.g. it's how the HTTP Server starts the registered callbacks.
To start the registered function in a new thread, call CtrlScript::startFunc(), e,g.
IntegerVar value(17);
script->startFunc("funcName", &value);
If you want to pass multiple values as arguments, use:
RecVar args;
args.append(new TextVar("first"));
args.append(new IntegerVar(17));
script->startFunc("funcName", &args);
Posted: Fri May 06, 2016 2:02 pm
by mmarchha
Works perfectly :woohoo:
One thing to add is how to get to the pointer of the script.
I'm doing it in the execute function.
e.g.:
const Variable *myExternHdl::execute(ExecuteParamRec& param)
  CtrlScript *script = param.thread->getScript();
Is this the correct way?
Posted: Fri May 06, 2016 2:13 pm
by mkoller
yes
