dpConnect keeps calling callback function
Posted: Thu Oct 03, 2024 4:26 pm
by Mgiacome
Hi
I've noticed that dpConnect() keeps calling the callback function, even if the value of the input parameters do not change.
dpConnect("callbackFunction", dp1:_online.._value)
If I put a DebugN inside the callbackFunction, I keep seeing in the log that the function is called.
dp input parameters have an OPCUA subscription as pheriphery address. But their value don't change.
There's something I'm missing ?
Thank you
Re: dpConnect keeps calling callback function
Posted: Tue Oct 08, 2024 2:55 pm
https://www.winccoa.com/documentation/W ... =dpconnect
you need to set answer parameter to false
Posted: Tue Oct 08, 2024 3:00 pm
by gschijndel
Perhaps the same value is written multiple times. Are other attributes (like the timestamp) changing?
Posted: Wed Oct 09, 2024 9:11 am
The "wantsAnswer" parameter only defines if the work function is triggered immediately when doing the dpConnect().
During runtime it has no effect if the parameter is set to to true/false.
Posted: Fri Oct 11, 2024 10:27 am
Oh, sorry. I misunderstood Mgiacome's problem.
Posted: Tue Oct 15, 2024 2:49 pm
by Mgiacome
Thanks all, the cause was the low level comparison setting unchecked inside the pheriphery address of the datapoint .... sorry
