Test Framework Coverage Report
Posted: Sun Aug 14, 2022 11:32 am
Hello All,
I recently opened a topic regarding to how to create test framework. Currently I am also trying to get the coverage report. I give coverage report input to testProj.[projName].config
The test runs successfully however no code coverage report xml has been generated under Results folder. However when I go to stored folder of test framework path projects, get into valid projects folder and open the last zipped project, I can see my coverage results under logs.
So why TestFramework is not generating these results under WinCC_OA_Test/Results folder?
Thanks
"ID": "TestRunAllUnitTests",
"NAME": "TestRunAllUnitTests",
"DESCRIPTION": "Tests all unit tests in given projects",
"PACK_SEL": 4,
"CTRL_COVERAGE": true,
"SUB_PROJS": ["MySubProj"],
"TEST_MANAGERS":
"MANAGER_OPTIONS": "tests/libs/classes/NewFile.ctl",
"MANAGER_OPTIONS": "tests/libs/classes/NewFile2.ctl",
"FILE_VERSION": "1.0"
Thanks
