createComObject() in CTRL manager problems
Posted: Tue Nov 09, 2010 11:35 am
Hi Guys,
Sorry to trouble you again with stupid questions but I have ran into a rather strange problem using the createComObject() function and I think I might be a bug. I created a function that calls createComObject() in a library named IPSS.ctl. The function works fine when called from a UI but not when called from a CTRL manager, I keep getting the following error message:
PVSS00ctrl (6), 2010.11.09 10:17:33.468, CTRL, WARNING, 78, Assignment to this expression impossible, IPSS_MiserDataImport.ctl, Count, Function not found
It looks as if PVSS doesn't recognise the "Count" property of the Excel.Application COM object, but the strange thing is that it works fine in a UI manager. I have added my library IPSS.ctl both to the [CTRL] and [UI] sections of my config file. Other functions in the library run fine except for this one. Any ideas??
My function code looks like this:
int IPSS_ReadExcelFile(string strFileName,
dyn_dyn_anytype &ddaFileContent)
// Extract the complete content of the Excel file requirested in the first parameter
// using the COM application interface provided by MS.
// Returns the file content in a dyn_dyn_any_type.
// Arguments required are:
// - strFileName, full path of the file to be extracted
// - ddaFileContent, a dyn_dyn_anytype variable to receive the information
DebugFN("IPSS", "** FUNC IPSS_ReadExcelFile **" + strFileName, isfile(strFileName));
if(isfile(strFileName))
dyn_string dsXlCol;
dsXlCol[1] = "A";
dsXlCol[2] = "B";
dsXlCol[3] = "C";
dsXlCol[4] = "D";
dsXlCol[5] = "E";
dsXlCol[6] = "F";
dsXlCol[7] = "G";
dsXlCol[8] = "H";
dsXlCol[9] = "I";
dsXlCol[10] = "J";
dsXlCol[11] = "K";
dsXlCol[12] = "L";
dsXlCol[13] = "M";
dsXlCol[14] = "N";
dsXlCol[15] = "O";
dsXlCol[16] = "P";
dsXlCol[17] = "Q";
dsXlCol[18] = "R";
dsXlCol[19] = "S";
dsXlCol[20] = "T";
dsXlCol[21] = "U";
dsXlCol[22] = "V";
dsXlCol[23] = "W";
dsXlCol[24] = "X";
dsXlCol[25] = "Y";
dsXlCol[26] = "Z";
idispatch xl;
idispatch xlWorkbooks;
idispatch xlWorkbook;
idispatch xlWorkSheets;
idispatch xlWorksheet;
idispatch xlRange;
anytype aRaw;
dyn_string dsTimeStamps;
dyn_float dfVals;
int intRows;
int intColumns;
/* Open Excel Object */
xl = createComObject("Excel.Application"); // Create the application interface
if(xl != 0)
xl.visible = FALSE; // Keep the file hidden from the user
xlWorkbooks = xl.Workbooks; // Get the Workbooks collection
xlWorkbook = xlWorkbooks.Open(strFileName); // Call the open event (inherited from the WorkbookEvents_Event)
xlWorkSheets = xl.Worksheets; // Get the Worksheets collection
xlWorksheet = xlWorkSheets.Item(1); // Item is a property inherited from Sheets
xlRange = xlWorksheet.UsedRange;
intRows = xlRange.Rows.Count; // Get the number of used rows
intColumns = xlRange.Columns.Count; // Get the number of used columns
for(int i = 1; i
