TRENDS CONFIGURATION
Posted: Thu May 30, 2013 11:04 am
by rohit.vadgama
I have configure trens in my project, but it is just showing trending for last two hours values.
what is to be done extra in my Configuration to get the trends of historic values ?Any scripting is neccessary to fetch old values for trend?
Re: TRENDS CONFIGURATION
Posted: Thu May 30, 2013 12:28 pm
by xavi.aran
hi! you need to configure this properties:
timeBegin
timeInterval
if you need to start the panel with a especific dates/hours.
Posted: Fri May 31, 2013 9:10 am
how much data can be displayed also depends on the amount of data stored in the database.
Maybe the settings for the database in your project are not correct and therefore you see only values for at least 2 hours.
Please check the settings for the database at the WinCC OA system management.
As we do not know which database you are using we cannot tell you which settings need to be checked and probably modified.
If you need further information please send a detailled support request to the official support.
How to make a service request is described at the FAQs.
https://portal.etm.at/index.php?view=it ... &Itemid=54
Posted: Mon Jun 10, 2013 10:40 am
by aorange
Is there any data in your database that is older than two hours?? are you keeping enough archive files online?
