OS Auth - "Unable to create user"
Posted: Wed Aug 04, 2021 5:04 pm
We are trying to figure out how to use OS Auth in our AD setup, by following the guidelines described here --> https://www.winccoa.com/documentation/W ... in-16.html. Everything seems to work until we try to login using one of the existing AD users, as even if the system seems to correctly validate the password it then fails to login with an popup error with the following message: "Unable to create user".
Our setup is as follows:
Project deployed is configured to use standard user manager (WinCC-OA accounts). Then I try to activate OS Auth in the following way:
Only clue we have is the following error in the application log (client side):
In server side the error is similar:
Any clue about the problem? What is this "external Id" is trying to determine?
- 1 Linux Samba4 AD controller.
- 2 redundant WinCC-OA Linux servers (Oracle Linux 8), running v3.18. These two servers run all managers in redundancy, except the UI ones.
- Several Windows 10 terminal clients using WinCC-OA DesktopUI v3.18 to connect to synoptics project.
- Login into a terminal client using one of the AD accounts (tried with and without administrative rights - no difference).
- Start DesktopUI, connect to synoptics project using "root" account.
- Go to "System Management -> "Permission" -> "User Administration": default WinCC-OA accounts are displayed, "OS Auth" option is available in "User Administration" menu, so apparently WinCC-OA correctly detects we are on a domain-controlled PC.
- Switch to "OS Auth" user administration and confirm all the popups.
- In group administration, I can import some groups from the domain controller and assign them permissions. No problems so far.
- Close to connection to synoptics and close Desktop UI.
- Relaunch DesktopUI, now login dialog correctly displays domain name in it.
- Try to login using a domain account -> Fails with error popup "Unable to create user".
WCCOAui (7), 2021.08.04 16:56:06.606, CTRL, SEVERE, 5/ctrl, Location of the following log entry:
Module: PVSS
Panel: C:\Users\jdoe\.wincc_oa-cache\MCC_Synoptics\panels\vision\login.pnl [Login]
In reference: vision/loginFramework/login_Standard.pnl Group: 0 named: "vision/loginFramework/login_Standard.pnl"
Script: ScopeLib
Library: C:\Users\jdoe\.wincc_oa-cache\MCC_Synoptics\scripts\libs\classes\userManagement\UserManagement.ctl
Line: 577
WCCOAui (7), 2021.08.04 16:56:06.606, PARAM,SEVERE, 0, , Error creating user: Cannot get external Id for user "jdoe"
WCCOAui (7), 2021.08.04 16:56:06.668, CTRL, SEVERE, 6/OaLogin, Unable to create user
WCCOActrl (1), 2021.08.04 16:56:06.604, CTRL, WARNING, 5/ctrl, Location of the following log entry: /opt/WinCC_OA/3.18/scripts/commandChannel.ctl Library: /opt/WinCC_OA/3.18/scripts/libs/classes/auth/OaAuthMethodAD.ctl
Line: 221
WCCOActrl (1), 2021.08.04 16:56:06.604, SYS, WARNING, 54, Unexpected state, /opt/WinCC_OA/3.18/scripts/commandChannel.ctl Library: /opt/WinCC_OA/3.18/scripts/libs/classes/auth/OaAuthMethodAD.ctl
Line: 221, Invalid argument (22)
