API C# on 3.17. How to Know ManagerNumber of OADriver
Posted: Thu Nov 05, 2020 11:17 am
also I need to acces to ProcessValues and ProcessModel to read ConfigPoints of My Driver.
How to send OAValue to WriteSingleValue
How to receive OAValue with DriverWriteValue handler.
I created a blob DP with config _address. I setup the Manager number with Para to My DriverManagerNumber (as is on Console). After writng value to My DriverManager DataPoint from Para I see Log message:
WCCOAKASKAD_set4tm(30), 2020.11.06 16:48:08.249, PARAM,SEVERE, 11, Datatype conversion incorrect - incompatible datatypes, DP: (Type: 293 Sys: 101 Dp: 3448 El: 6 : _original.._value), MAN: (SYS: 101 Driver -num 30 CONN: 1), M.6.6.5
at the same time DriverManager not Receive a message from WinCCOA and this Code not running:
Driver.DriverWriteValue += (vcsender, vce) => {
Console.WriteLine("Set4TMDriverApp.DriverWriteValue{0}", string.Join(",", vce.Data.Select(v1=>v1.ToString())));
