Customalert
Indrani125
Customalert
Post by Indrani125 »
I am unable to save anything under message catalog of wincc oa..so unable to see customize alert.can you tell reason why I am not able to save after writing keyword and message?I am saving but afterward it is not found in catalog :?
dbindernagel
Re: Customalert
Post by dbindernagel »
Are you trying to change a message catalog from a sub project?
If you change files of a sub project in the Gedi these files get copied and saved in your project.
The original file of the sub project remains unchanged.
Indrani125
Re: Customalert
Now it is getting entered but unable to see as custom alert through script..can you help?
dbindernagel
Re: Customalert
The name of your message catalog in your project is "Catalog". In your script you are trying to use a message catalog with the name "CustomAlerts" which does not exist in your project. So either create a new message catalog with the name "CustomAlerts" or use the already existing message catalog "Catalog".
In the script editor you can right click on a CONTROL function to open the help to get a description of how the function should be used.
Indrani125
Re: Customalert
Hey!Thank you :-)
