EIP Ethernet/ip driver connection error
imhht1311
Post by imhht1311 » Fri Mar 27, 2020 4:56 am
I tried to communicate OMRON PLC using EIP Ethernet/IP Driver.
Two programs are same config.
example) Device driver is Allen-Bradley ControlLogix Ethernet, same IP address, same Slot number, same tag address
When Trying to communicate OMRON PLC using Kepware program, I received "Success: Connection Manager - Forward Open"
but When Trying to communicate OMRON PLC using WINCC OA program, I received "Connection failure: Connection Manager - Forward Open"
I want to communicate OMRON PLC using EIP Ethernet/IP Driver.
I used 'CJ2H-CPU64-EIP'
WINCC OA Version is 3.14 patch 31
Please Help me.
Re: EIP Ethernet/ip driver connection error
Post by leoknipp » Fri Mar 27, 2020 7:50 am
Please check the PVSS_II.log file for this project if an error is reported for the EIP driver when trying to establish the connection to the device.
imhht1311
Post by imhht1311 » Fri Mar 27, 2020 8:09 am
I checked PVSS_II.log.
It said that "Connection error, EipStackWrapper, Stack error, *ERROR* Failed to start connected-mode session. Err: CIP Error 0X001: Connection Failure"
So, I used -dbg 2 try to find error.
WCCOAeip (99), 2020.03.27 17:07:09.165, IMPL, SEVERE, 63, Connection error, EipStackWrapper, Stack error, *ERROR* Failed to start connected-mode session. Err: CIP Error 0x0001: Connection Failure
WCCOAeip99:>> "Operation: Echo, Type: Logix, TagCount: 0"
WCCOAeip99:WCCOAeip (99), 2020.03.27 17:07:09.145, WORK, EipPlc::sendRequest (Echo) to EIP_TEST in state 3
WCCOAeip99:WCCOAeip (99), 2020.03.27 17:07:09.146, WORK, EipPlc::updateConnState(4)
WCCOAeip99:WCCOAeip (99), 2020.03.27 17:07:09.146, WORK, EipPlc::ProcStateChange(EIP_TEST): Registering session
WCCOAeip99:WCCOAeip (99), 2020.03.27 17:07:09.156, WORK, EipPlc::ProcStateChange(EIP_TEST): Busy
WCCOAeip99:WCCOAeip (99), 2020.03.27 17:07:09.156, WORK, EipPlc::ProcStateChange(EIP_TEST): Ready
WCCOAeip99:WCCOAeip (99), 2020.03.27 17:07:09.156, WORK, EipPlc::updateConnState(2)
WCCOAeip99:WCCOAeip (99), 2020.03.27 17:07:09.164, WORK, EipHWService::generalQuery called for PLC "EIP_TEST"
WCCOAeip99:WCCOAeip (99), 2020.03.27 17:07:09.164, WORK, EipPollGroup::EipPollGroup(0)
WCCOAeip99:WCCOAeip (99), 2020.03.27 17:07:09.164, WORK, EipPollGroup::~EipPollGroup("")
WCCOAeip99:WCCOAeip (99), 2020.03.27 17:07:09.187, WORK, EipPlc::ProcStateChange(EIP_TEST): Disconnect request from stack
WCCOAeip99:WCCOAeip (99), 2020.03.27 17:07:09.188, WORK, EipStackWrapper::disconnect(): plc="172.16.14.210"
WCCOAeip99:WCCOAeip (99), 2020.03.27 17:07:09.188, WORK, EipPlc::ProcStateChange(EIP_TEST): Busy
WCCOAeip99:WCCOAeip (99), 2020.03.27 17:07:09.188, WORK, EipPlc::ProcStateChange(EIP_TEST): No active session
WCCOAeip99:WCCOAeip (99), 2020.03.27 17:07:09.189, WORK, EipStackWrapper::disconnect(): plc="172.16.14.210"
WCCOAeip99:WCCOAeip (99), 2020.03.27 17:07:09.189, WORK, EipPlc::updateConnState(3)
WCCOAeip (99), 2020.03.27 17:07:11.179, SYS, INFO, 0, , EipPlc, ConnEstablished, Established connection to plc EIP_TEST
and then, I compared between WINCC OA's Packet and Kepware's Packet using Wireshark.
