Primitive text - transformable
srg@tratec.no
Post by srg@tratec.no » Tue Mar 24, 2020 10:56 am
I need to rotate a primitive text in a script. Using property "rotation" does not work directly. In GEDI one needs to set "transformable" first, but I cannot seem to find the correct way to set this using setValue?
Re: Primitive text - transformable
Post by leoknipp » Fri Mar 27, 2020 7:39 am
Why is there a need to set the "transformable" attribute via script?
If you already know that you want to the have it transformable you can set it in GEDI.
