Can I make the WINNOA project run when the PC starts?
SMT_SOL
Post by SMT_SOL » Wed Mar 18, 2020 1:51 am
At the end of the Wincc Oa project controller, the user interface is running a vision.
Is there a way to automatically start the project's vision when the PC restarts?
adaneau
Re: Can I make the WINNOA project run when the PC starts?
Post by adaneau » Wed Mar 18, 2020 9:57 am
Ha, this one is tricky :)
Guess you already configured your project to start as service but UI doesnt show up at the end. This is normal as Windows prevents interactive services.
However there is a solution : the startup folder where you can put programs to start after login of user.
https://tunecomp.net/add-program-to-startup-windows-10/
So you just put your UI shortcut there, with good options to start relevant project (-proj, -p, and so on). Then you'll see your UI starting after login into computer.
Regards
Alexandre
SMT_SOL
Post by SMT_SOL » Mon Mar 23, 2020 2:13 am
Thank you for your kind answer ~
I set the UI options according to the answer. But
I don't know how to create a UI shortcut...
Post by kilianvp » Mon Mar 23, 2020 8:42 am
The Path is:
C:\Siemens\Automation\WinCC_OA\<VERSION>\bin\WCCOAui.exe -PROJ <PROJ> <OPTIONS>
replace <VERSION> with your WinCC OA version, <PROJ> with your project name and <OPTIONS> with your options.
the options can be taken from the WinCC OA console
For example:
-m vision -p vision/login.pnl -menuBar -iconBar -centered
-m gedi
SMT_SOL
Post by SMT_SOL » Tue Mar 24, 2020 12:35 am
Thank you for your kind answer :D
As you follow the answer, the vision is executed. But I have a small problem.
Vision does not work because start Project is not executed in WinccOa Console.
What should I do?
adaneau
Post by adaneau » Wed Mar 25, 2020 11:01 am
Go to online help of Wincc OA and check the section for running Wincc OA as a service. This is prerequisite for using this method as I wrote in my first post.
Regards
Alexandre
