Requirements for OS Authentication
fleitner
Post by fleitner » Mon Jan 13, 2020 3:39 pm
we are in the process of creating a WinCC OA project with Active Directory authentication.
On our development machines, we can switch to AD authentication ('OS Auth.') and use our corporate AD.
Now we want to create a test machine in the customer environment to start testing in their environment and their AD.
However, the option 'OS Auth.' is not in the list under user administration, only the empty field and 'Standard'.
In both cases, the user is a normal domain user.
What is the trigger used by WinCC OA that makes the option 'OS Auth.' available?
Is there a way I can test this requirement on the command line?
WinCC OA: 3.16 P012
Windows 10
Frank
Re: Requirements for OS Authentication
Post by leoknipp » Tue Jan 14, 2020 12:15 pm
If you want to switch the authentication type you must be root user.
Please check if the panel works when running as root user.
Post by gschijndel » Wed Jan 15, 2020 2:36 pm
A windows machine must be part of a domain.
fleitner
Post by fleitner » Mon Jan 20, 2020 7:45 am
Thank you for the answers. It turns out there was an issue with domain connectivity on the customer network, which likely caused this issue.
