[3.14] Retrieve current Panel (Window) Size
moto3101
Post by moto3101 » Mon Oct 07, 2019 5:12 pm
Hello together,
I do have a problem with the method panelSize():
int panelSize (string PanelName, int &width, int &height, bool currentSize = false);
If you have a panel which has no layout, and you drag the panel to increase the size, panelsize() will always return the same value (I do understand the panel will not change its size, if there is no layout defined and you change the window size).
However, is there a way to obtain the 'window size' during runtime for an opened not-layouted panel?
Thanks in advance!
Re: [3.14] Retrieve current Panel (Window) Size
Post by leoknipp » Tue Oct 08, 2019 8:11 am
Are you opening the panel as a child panel or in an own module?
What is the information of the size used for?
Post by gschijndel » Wed Oct 09, 2019 2:49 pm
In case the contents are scaled you could get the 'window size' by multiplying the width and height (as returned by panelSize) with the zoom factor.
moto3101
Post by moto3101 » Wed Nov 13, 2019 12:29 pm
Hi Leopold,
sorry for my belated reply. I opened it with ChildPanelOnModule.
@gschijndel: What method do you use to obtain the window size?
Morten
Post by leoknipp » Wed Nov 13, 2019 3:59 pm
Are you sure that you are using a panel without a layout and open it as a child panel?
A panel which has no layout cannot be resized if it is opened as child panel.
