How to know if para panels are opened?
9 posts • Page 1 of 1
sblancha
Post by sblancha » Mon Aug 05, 2019 1:55 pm
I have checked system overview of the winCC OA application but seems it reports only user interfaced opened. How to know how many from which client para panel are currently opened?
Sebastien
Re: How to know if para panels are opened?
Post by leoknipp » Tue Aug 06, 2019 6:47 am
You can try if the function getParaNames() returns the correct result.
sblancha
Post by sblancha » Tue Aug 06, 2019 8:21 am
Thanks for the fast answer.
The function seems to always return nothing whatever paras are opened or not and in help I found:
"Lists all the open PARA modules. The function is obsolete as of WinCC OA version 3.6. The function is, however, available for compatibility reasons."
sblancha
Post by sblancha » Tue Aug 06, 2019 8:24 am
Maybe something else may help me. I'd like to check if some dpe are locked. I can parse all dpe of my project and check the _lock config but I wonder if there is an easier way?
sblancha
Post by sblancha » Tue Aug 06, 2019 8:32 am
Another question: if dpe is _lock, dpSet() do nothing and return -1 Correct? is there an error message in the PVSS log? or I have to getLastError() and print it?
Piterskiy
Post by Piterskiy » Tue Aug 06, 2019 8:39 am
You could also do a dpQueryConnectSingle on datapoints of "_Ui" DPT
then check DP.RootPanelOrigOn.FileName dpe if it is equal para/original.pnl then process it
Upd. If use this approach, that should be a Ctrl function that start working when project launches (as CTRL Manager). See Leopold remark.
sblancha
Post by sblancha » Tue Aug 06, 2019 9:11 am
dpQuery to _Ui* works fine thanks for the tips.
Post by leoknipp » Tue Aug 06, 2019 9:49 am
Reading the _UI datapoint only returns the information for the panel which was opened last.
If someone has opened a PARA before you will not get the information.
For the function dpSet() you cannot use getLastError() to check if an error occured because dpSet() is not a waiting function.
If you use dpSetWait() a check with getLastError() is possible.
sblancha
Post by sblancha » Thu Aug 08, 2019 8:44 am
Ok thanks for the details
