Recovering old archive values
jonred
Post by jonred » Fri Jul 05, 2019 12:14 pm
a client is storing some data in archive_1. LAter, we added more data to that archive (same datapoints type, usign ascii manager). because a config mistake, the data stored is from about 5 months now, when previously it was for about 2 years. they noticed when trying to report the last current year data. i changed the stored datapoints in archive configuration, so the data should be strored correctly now, but i need to recover the old data.
I made a copy of the project and tested the method in my test enviroment.
I tried to delete the archives and restore archives from online backup using th option from database configuration -> Activity, but the archives don't appear and data can't be retrieved via repottings -> sql query. The files are actually copied from de backup directory to the project directory, but WinCC OA can't "see" them.
Now, i only have last file data. (i am using a copy of the project in my lab)
¿What is the reason for this?
Thank you very much
Re: Recovering old archive values
Post by leoknipp » Mon Jul 08, 2019 8:04 am
Possibly the old files are already marked as "deleted" and therefore you cannot access the files.
You can try to
-- configure a backup directory for the value archive
-- copy the old archive files to this directory
-- use the archive configuration panels to restore the files
jonred
Post by jonred » Wed Jul 10, 2019 1:49 pm
Thank you, I tried that in my lab and i could recover the old data.
In a redundant system, i suposse i have to delete the online files to recover from both servers, and then recover using the activity panel in the active host, true?
Thank you very much
