Add value to RAIMA archive through ALERTSET function
orla090978
Post by orla090978 » Tue Apr 16, 2019 2:07 pm
Hi everybody,
I'm trying to write value (for example "_add_value_1" to an alert) to alarm table using ALERTSET function.
Well, function works but only for last alarms occurences and not for the previous occurences for the same alarm.
Have any idea about this issue?
Thanks a lot.
adaneau
Re: Add value to RAIMA archive through ALERTSET function
Post by adaneau » Tue Apr 16, 2019 2:15 pm
Maybe this from help will help:
I guess that your previous occurrences are already WENT or ACK.
Alexandre
orla090978
Post by orla090978 » Tue Apr 16, 2019 2:41 pm
It works.
Thank you Adaneau.
Post by leoknipp » Tue Apr 16, 2019 3:13 pm
I made a test and you have to use the attribute _add_values if you want to set add values for alerts which do not belong to the current alert.
E.g the following order of alerts is given for a specific DPE
AL1 - Alert came
AL1 - Alert gone
AL2 - Alert came
For the alert pair AL1 you have to use _add_values, for AL2 you can use _add_value_X.
_add_values works all the time, also for the current alerts.
