Add a new executable to Wincc Project
ange.ogawin
Post by ange.ogawin » Mon Apr 15, 2019 3:48 pm
I have the following message that appears when i want to create an instance of a personal driver(not the ones
of Wincc).
I added the .exe in the bin directory of DemoApplication and wanted to load my new driver through the console.
Any idea of what could be the issue?
PS: I am able to add SampleDriver.
Thank you.
adaneau
Re: Add a new executable to Wincc Project
Post by adaneau » Tue Apr 16, 2019 9:13 am
I dont think this is related to your .exe.
You need to use the highlighted button to add it at the end of the list, as in a running project, manager position cannot change
Otherwise you can also stop whole project and it should be fine.
Alex
ange.ogawin
Post by ange.ogawin » Tue Apr 16, 2019 9:35 am
Thank you for your reply. However, the same message is displayed although the whole project is stopped, and
when i want to add at the end of the list.
adaneau
Post by adaneau » Tue Apr 16, 2019 9:46 am
Hum that's quite strange. Could you try following?
  • Stop project
  • Close all WInCC OA windows
  • Go to your project folder and open progs file
  • Add your manager to progs file using a text editor and save it
  • Open console, see if your manager is here
  • If yes try to start
Alex
ange.ogawin
Post by ange.ogawin » Tue Apr 16, 2019 10:03 am
Thank you much.It's working. When i tried to edit the prog file, it wasn't working.So i tried to change the name of the .exe file because
it was a bit long, in order to match the same format of other lines in the progs file. And it worked.
I am able to add the driver through the console now.
Re: Add a new executable to WinCC OA project
Post by gschijndel » Wed Apr 17, 2019 7:55 am
So i tried to change the name of the .exe file because it was a bit long
The pmon should be able to handle executables up to 19 characters long (including the 'WCCOA' prefix).
