Hello everybody,
Does SysLog supported by WinCC OA 3.16?
It is useful to exchange with plant log information.
Thanks a lot
SysLog
Re: SysLog
Can you please describe more detailed what the question/requirement is.
Which operating system are you using?
Re: SysLog
Thanks for reply.
Below some details about the topic:
Our customer have an SIEM (security information and event management) server (based on IBM cybersecurity Qradar platform) where are collected all events related to security.
Customer requires that login and logout events in SCADA application shall be send to SIEM system through SYSLOG protocol (this protocol is not supported by Windows but there are some libraries that support this).
Does WinCCOA support the libraries described above?
The event result will be similar to the following (JSON format):
"Severity":"Info",
"Timestamp":"2019-03-31T12:02:05.836",
"System":"SCADA",
"Component":"SCADAGUI",
"Function":"Authentication",
"Message":"Login on SCADA by user domain\username",
"Operation":"Login",
"User":"username",
"Host":"localhost"
Best regards.
"Severity":"Info",
"System":"SCADA",
"User":"username",
"Host":"localhost"
Best regards.
Re: SysLog
No but you can do that by your own. We have some customer who print out every event.
Im sure you can use some kind of REST API.
Best regards.
Best regards.
Re: SysLog
Who manages this library? WinCC OA or our SIEM server?
Thanks a lot
Thanks a lot
