ctrl++ object transfer via dollar parameter
Posted: Tue Dec 04, 2018 3:43 pm
by philipp.wechsler
Is it possible to transfer ctrl++ object via dollar parameter to an other panel?
There is a mwe:
Library
class AlertItem
  protected string mName;
  protected bool mState;
  public AlertItem( string pName, bool pState )
    mName = pName;
    mState = pState;
  public string getName()
    return mName;
  public bool getState()
    return mState;
Initialize panel-code:
main()
  AlertItem ai1 = new AlertItem( "MyAlert", true );
  addSymbol( myModuleName(), myPanelName(), "oo-test-object.xml", "MyRef", makeDynString( "$ai:" + ai1 ), 20, 20 );
Initialize oo-test-object.xml:
main()
  AlertItem ai1 = $ai;
  lblText.text = ai1.getName();
  rect.backCol = ai1.getState() ? "blue" : "white";
How can I transfer an object to a next reference?
With kind regards
Philipp
Re: ctrl++ object transfer via dollar parameter
Posted: Tue Dec 04, 2018 4:54 pm
The parameters which can be passed to a reference are of type dyn_string.
I think therefore you cannot pass "objects" to a reference.
Posted: Tue Dec 04, 2018 7:02 pm
by mkoller
You can not pass an object via $-parameter.
However you can call a public function in that Panel Reference, which has any datatype as argument.
So do it in 2 steps:
1) addSymbol()
2) call the public function in the newly added symbol
Posted: Wed Dec 05, 2018 8:34 am
by philipp.wechsler
Thanks a lot Martin!
Yes, that works with the public method. I can fix it by moving the statements from the init method to this public method. The construction happens now two steps. I want to investigate the building process.
With kind regards
Philipp
