WinCC OA Video
Posted: Mon Dec 03, 2018 10:06 am
by uxout
Hello !
I want to add RTSP stream into WinCC OA via the WinCC OA Video feature but I can't make it work as properly.
I'm running WinCC OA 3.15P15 on Windows.
I've tried with a dongle licence and also without licence (demo licence).
I've copied the files LicenseFeatures.opt_BAK1 to LicenseFeatures.opt and LicenseFeatures.sgn_BAK1 to LicenseFeatures.sgn from the xxx/vimacc/data/features/license to WinCC_OA directory.
vimacc screenshot
log
Anyone knows why can't I use the VimAcc module?
Re: WinCC OA Video
Posted: Fri Dec 07, 2018 4:31 pm
by acx.lilienthal
your shared files are blocked for access and maybe important to understand, what's exactly is not working.
* What is the object explorer looks like?
* Which steps did you performed to make it running?
* Did you installed it in a clean way or did you performed an update?
* Did you imported the encryption key from vimacc to your OA project?
Best Regards,
Benjamin Llienthal
Re: WinCC OA Video
Posted: Fri Dec 07, 2018 4:55 pm
by uxout
I just updated the file sharing options, you should be able to see the pictures.
- The object explorer looks like in my first screenshot.
- I had a previous WinCC OA 3.15 installed on my computer. So was Vimacc.
I copied the 2 files LicenseFeatures.opt_BAK1 and LicenseFeatures.sgn_BAK1 from C:\\vimacc\\data\\features\\license to C:\\Siemens\\Automation\\WinCC_OA\\3.15 and renamed them without _BAK1.
I created a new WinCC OA project and added VIDEO_3.15 as sub project.
I added the 2 managers WCCOAvideoOA and WCCOAvideoOA -f VIDEO_OA_scripts.lst
I started the project and imported VIDEO_OA_complete.dpl from the VIDEO_3.15\\dplist\\
That's all, anything i forgot to do?
- My WinCC OA installation got several update from 3.15P1, do you think it is due to the updates?
- Yes, i guess it is what I mentioned earlier, right?
Thanks for your help.
Re: WinCC OA Video
Posted: Fri Dec 07, 2018 5:23 pm
by acx.lilienthal
this looks like an open issue in current patches of 3.15, when updating from further uncrypted to the new fully encrypted video installation (including stream & recording encryption).
Please perform the following steps to get a clean installation of WinCC OA Video:
- Open the Windows menu "Apps & Features" (first option when pressing + 'X')
- Select "WinCC OA 3.15", trigger "Change" and use the selection option to adjust the installation.
> Deselect the option "Video Add-On"
> Let the setup perform the changes.
- Deinstall "vimaccOA 2.2.4.*"
- Delete the folder "C:\\vimacc"
- Perform the setup of "WinCC OA 3.15" again from the "Apps & Features" menu with the option to adjust the installed components.
> Select the option "Video Add-On"
To make your project running, please perform the following additional steps:
- Delete a maybe existing file "vimacc_keys.pem" from the folder "/data/videoOA" in your project path.
- Use the button "Import vimacc keys" in the Video Object Explorer to import encryption keys to your project AND restart the Video Manager.
Please give a short feedback, if these steps fixes the issue.
Benjamin Lilienthal
Re: WinCC OA Video
Posted: Fri Dec 07, 2018 11:01 pm
by acx.lilienthal
PS:
Do not copy any LicenseFeatures files from vimacc folder to the WinCC OA folder. This is not needed and does not help in any kind.
Re: WinCC OA Video
Posted: Wed Dec 19, 2018 5:23 pm
by uxout
Hello !
Sorry for the late reply, it finally worked, I can use the video module.
Thanks again !
