SysLog
Discussion about security topics in WinCC OA!
7 posts • Page 1 of 1
ilariabonori
SysLog
Post by ilariabonori » Thu Mar 21, 2019 2:01 pm
Hello everybody,
Does SysLog supported by WinCC OA 3.16?
It is useful to exchange with plant log information.
Thanks a lot
Re: SysLog
Post by leoknipp » Fri Mar 22, 2019 9:50 am
Can you please describe more detailed what the question/requirement is.
Which operating system are you using?
ilariabonori
Re: SysLog
Post by ilariabonori » Fri Mar 22, 2019 1:27 pm
Thanks for reply.
Below some details about the topic:
Our customer have an SIEM (security information and event management) server (based on IBM cybersecurity Qradar platform) where are collected all events related to security.
Customer requires that login and logout events in SCADA application shall be send to SIEM system through SYSLOG protocol (this protocol is not supported by Windows but there are some libraries that support this).
Does WinCCOA support the libraries described above?
The event result will be similar to the following (JSON format):
"Severity":"Info",
"Timestamp":"2019-03-31T12:02:05.836",
"System":"SCADA",
"Component":"SCADAGUI",
"Function":"Authentication",
"Message":"Login on SCADA by user domain\username",
"Operation":"Login",
"User":"username",
"Host":"localhost"
Best regards.
Re: SysLog
Post by kilianvp » Fri Mar 22, 2019 1:44 pm
No but you can do that by your own. We have some customer who print out every event.
Im sure you can use some kind of REST API.
Best regards.
ilariabonori
Re: SysLog
Post by ilariabonori » Fri Mar 22, 2019 2:57 pm
Who manages this library? WinCC OA or our SIEM server?
Thanks a lot
vsolomonidou
Re: SysLog
Post by vsolomonidou » Thu Jan 09, 2020 2:59 pm
Would you suggest to build a custom API manager/driver for pushing Wincc OA data to a syslog server?
Is it possible to use the SNMP manager to establish a connection to a syslog server?
Vaso
Re: SysLog
Post by leoknipp » Tue Jan 14, 2020 10:53 am
If you need to build an own manager for the communication to the syslog server depends on the interfaces the syslog server supports.
Please check with the vendor of the syslog server if there any interfaces which can be used.
