Making a print screen of a child panel
7 posts • Page 1 of 1
nmnogueira
Post by nmnogueira »
I already created a script for making print screens of all the alarms in the Panel Topology. It opens the panels one by one in the User Interface, and makes a print by using the function
setValue("WinCC_OA_1" + "." + "Basepanel" + ":", "imageToFile", sPath);
This works like a charm.
Now I am trying to make a script to make a print screen of all the Operating panels. I can find a way of opening each panel as a child panel, but how do I make a print of this panel?
(i.e how do I make a print of a panel that was open using ChildPanelOnModule)
Thanks!
Re: Making a print screen of a child panel
Should work with the CTRL function printPanel()
Just replace "Basepanel" with the name of your childpanel.
Instead of opening every panel as a child panel you could also open it as a root panel in an own module.
If you want to make a print screen of every panel you have to check if $-parameters need to be passed. Otherwise your panels will probably not work and will display wrong or no information.
RudiKreiner
Post by RudiKreiner »
yavaskoray
Post by yavaskoray »
The link is not valid anymore, how can i access that link? Also, is there any new solution from WinCC OA to print with childpanels?
Thank you.
You still have to use printPanel()
