Audit Trail database settings
tmalone
Post by tmalone »
We would like to use the Audit Trail feature and dedicate the old "Day Archive #3" for this functionality.
Is there some optimal settings for Audit Trail in Value Archives? For example, would it be best to expand the "Max size for dyns and texts"?
Todd Malone
Trident Maritime Systems
Re: Audit Trail database settings
The _AuditTrail datapoint does not use dyn-arrays, only a few dp elements of typ "string" are defined.
As the _AuditTrail elements are normally only written if a user is doing an important command (which needs to be documented) there is no need to do an optimization.
