can't change node name on top level panel topology node?
Posted: Mon Apr 19, 2021 7:25 pm
by tpjctrl
For some reason when I go into the Panel Topology / Node Properties of the top level node (called StartPanel currently), the name is grayed out and cannot be changed. Any ideas why? can this be modified from a dp level (in _PanelTopology dp) or would that break something elsewhere (I'm guessing it would)?
Re: can't change node name on top level panel topology node?
Posted: Fri Apr 23, 2021 8:17 am
It looks like a limitation in code/design of the Panel Topology that you cannot change the name for "StartPanel".
Posted: Tue May 11, 2021 12:16 pm
by tpjctrl
Ah but it's changeable in some places, but for the life of me I can't figure out what controls the ability to edit the top level node name :/
Would changing it directly in the dp (in _PanelTopology dp) "break" something? is that top level node name used elsewhere for referencing perhaps?
Posted: Wed May 12, 2021 2:12 pm
Have you been able to modify it in the panels used for the panel topology?
I didn't check if changing the name will cause any problems.
You can try it on your own to see if it has any negative effect.
