How to construct a popup Menu with Icons and text
9 posts • Page 1 of 1
GerrieF
Post by GerrieF »
How can I use the popupMenuXY to construct a contextual menu with buttons and Cascade buttons having an icon as well as a text label?
This is done for the Gedi menu bar, but I am unable to find an example for the construction.
Re: How to construct a popup Menu with Icons and text
Post by gschijndel »
There is a hidden feature, which makes it possible to set a 'popup' flag for child panels. If this flag is set the child panel is closed if a mouse click occurs outside the child panel.
Perhaps 3.18 contains an example using this 'popup' flag.
GerrieF
Post by GerrieF »
Thank you for your reply to my post!
GerrieF
Post by GerrieF »
gschijndel wrote: Mon Mar 29, 2021 1:28 pm There is a hidden feature, which makes it possible to set a 'popup' flag for child panels. If this flag is set the child panel is closed if a mouse click occurs outside the child panel.
Can you tell me a little more about the hidden "popup" flag?
I am fairly new to OA and I am trying to construct a contextual menu for a client's CMS system based on Google Material design guidelines.
My problem is that I cannot add the icons to the buttons when I create the menu using "popupMenyXY".
Any help on this will greatly be appreciated.
In the upcoming version 3.18 a new reference object (objects/popupMenu/MenuButton.pnl) is available which can open a popup menu with text and icon.
You can possibly wait for the release of 3.18 and then have a look at the new reference object.
GerrieF
Post by GerrieF »
leoknipp wrote: Thu Apr 01, 2021 8:42 am In the upcoming version 3.18 a new reference object (objects/popupMenu/MenuButton.pnl) is available which can open a popup menu with text and icon.
Good day Leopold
Thank you for this reply.
Do you know when version 3.18 will be released?
The release of 3.18 is planned for May 2021.
Information for the future releases you can find in the following pdf document:
https://www.winccoa.com/downloads/detai ... 14b76451d0
emanuel.b
Post by emanuel.b »
I was searching for something similiar too and found the solution with that "hidden feature" (see the windowFlags -> Popup below), see following snippet.
  int x, y;
  getValue(this, "position", x, y); // just an example ...
  dyn_string dollars = makeDynString(); // whatever to pass ...
  dyn_anytype da = makeDynAnytype(myModuleName(), "yourPanelToShow.xml", myPanelName(), "somePanelName",
                                  x, y , 1.0, true, dollars, false, makeMapping("windowFlags", "Popup"));
  dyn_anytype results;
  childPanel(da, results);
Emanuel
GerrieF
Post by GerrieF »
emanuel.b wrote: Wed Apr 14, 2021 4:55 pm Hello,
  int x, y;
Emanuel
This will work great if I create a child panel, thanks.
I will defiantly keep this in mind for the design.
